Apologies for seeming dense but I’ve only just joined the forum and can’t find the link to send you a pm
Power sliding doors are different to power latching - the forum sell the power latching kits so you can just gently push the door to its closing point and let the latch pull it closed, but as for power-sliding... I think @Robert has a DIY on the go:Hi, Can you supply and fit the power sliding doors and tailgate to t6 18 reg Lwb transporter shuttle. Is it the same as the VW factory supplied upgrade?
Yes they do
have sent a couple out for T5.1s but think the power on the motor needs to be reversed as they seem to run the other way, could be that the negative return from the door switch is the opposite way around ie normally closed/normally open ?
Haven’t got one to test so can’t be sure but worst case you will need to reverse two wires in one of the connectors
Send me a message if you are interested but have a bit of a back log at the moment so will need a few days to get a kit together
