Cheers...Keep watching this space.
Full guidance and part list will be provided as usual.
I suspect that your reversing lights are PWMed and this is causing camera misbehaviour. Connect your reversing trigger to permanent 12V DC for testing purposes or alternatively deactivate Byte 11 Bit 4 in your BCM.Gdn is conected to brown in lamp yellow to grren in lamp red to de red in head unit
In this case you have to test your camera on your home TV or any appropriate LCD screen/monitor.No don't help I try both coding and permament power
Yes it will, assuming your camera is in good working condition.Will work with tv?
Curious if actually these are related - what has happened to Airbag key switch?Yes the abs fault is with plain coding
I wish I was wrong but I think your camera is faulty.And camera not working on tv
Yes, as long it is producing video signal in CVBS standard( generally speaking almost all coaxial cable type setups).So can i conect to hed unit any analog camera or dvd player for test?
