Monday,14,December,2020,14:13:09:53228
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 20.12.0.1 (x64) HEX-V2 CB: 0.4529.4
Data version: 20201125 DS322.1
www.Ross-Tech.com
VIN: WV1ZZZ7HZJH023306 License Plate:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 02 03 04 08 09 10 13 15 17 19 25 55 5F 61 6C 0B
VIN: WV1ZZZ7HZJH023306 Mileage: 48380km-30061miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: Malfunction 0010
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
6C-Back-up Cam. -- Status: Malfunction 0010
Address 01: Engine (2D2D2-CXEB) Labels:. 04L-907-309-V2.clb
Part No SW: 04L 906 056 KQ HW: 04L 907 445 A
Component: R4 2.0l BTD H03 3775
Revision: 23101001
Coding: 00254014432401080000
Shop #: WSC 02737 790 50316
ASAM Dataset: EV_ECM20BTD03004L906056KQ 004004
ROD: EV_ECM20BTD03004L906056KN_004.rod
VCID: 0655941628ABD3FB49E-8052
2 Faults Found:
25577 - Engine Start Blocked by Immobilizer
P1570 00 [096] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 19
Mileage: 47697 km
Date: 2038.01.11
Time: 06:08:58
Engine RPM: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 21 °C
Intake air temperature: 19 °C
Ambient air pressure: 980 mbar
Voltage terminal 30: 11.539 V
Unlearning counter according OBD: 7
Immobilizer Snapshot 001 Byte 1: 9F
Immobilizer Snapshot 001 Byte 2: FF
Immobilizer Snapshot 001 Byte 3: CF
Immobilizer Snapshot 001 Byte 4: 1A
Immobilizer Snapshot 001 Byte 5: 20
Immobilizer Snapshot 001 Byte 6: 00
Immobilizer Snapshot 002 Byte 1: 00
Immobilizer Snapshot 002 Byte 2: 00
Immobilizer Snapshot 002 Byte 3: 00
Immobilizer Snapshot 002 Byte 4: 00
Immobilizer Snapshot 002 Byte 5: 00
Immobilizer Snapshot 002 Byte 6: 00
Immobilizer Snapshot 004 Byte 1: 00
Immobilizer Snapshot 004 Byte 2: 00
Immobilizer Snapshot 004 Byte 3: 00
15560 - EGR Sensor 1
P046C 00 [104] - Implausible Signal
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 47697 km
Date: 2038.01.11
Time: 05:11:59
Coolant temperature: 37 °C
Intake air temperature: 20 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 12.804 V
Unlearning counter according OBD: 32
Mass airflow sensor 1 bank 1 airflow: raw value: 0.0 mg/stroke
Exhaust recirc.valve 1 bank 1: posit.feedback - Specified value: -4.01 %
Exhaust recirc.valve 1 bank 1: posit.feedback - Actual value: -3.96 %
Exhaust recirc.valve 1 bank 1: posit.feedback - Offset closed: 0.00 %
Exhaust recirc.valve 1 bank 1: posit.feedback - Raw voltage: 2.498 V
EGR vacuum regulator solenoid valve 1 bank 1: res. Cooling mode stop: 2.332 V
EGR vacuum regulator solenoid valve 1 bank 1: res. Bypass operation stop: 2.800 V
Readiness: N/A
Address 02: Auto Trans (J743) Labels:. 0BH-927-711.clb
Part No SW: 0BT 300 046 J HW: 0BH 927 711 G
Component: DSG DQ500-7F H11 5302
Revision: 00H11V01
Coding: 0014
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_TCMDQ500021 001001
ROD: EV_TCMDQ500021_A01_VW36.rod
VCID: 3D273BFA3DFD5023584-8068
No fault code found.
Address 03: ABS Brakes (J104) Labels: 7E0-907-37x-MK100ESC.clb
Part No SW: 7E0 907 379 P HW: 7E0 907 379 M
Component: ESC H06 0133
Revision: 00000000 Serial number: 41747000000407
Coding: 347E4098656484812C780276A68821D379F100
Shop #: WSC 02739 790 50316
ASAM Dataset: EV_Brake1ESCCONTIVN75XGP2 011001
ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
VCID: 3FDB41F237F142334A8-806A
1 Fault Found:
0397 - TPMS Warning
C102D F0 [008] - Pressure Loss
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 7
Mileage: 47718 km
Date: 2020.12.05
Time: 01:38:43
Address 04: Steering Angle (G085) Labels:* 6R0-959-654.clb
Part No SW: 6R0 959 654 HW: 6R0 959 654
Component: LENKW.SENSOR H07 0070
Serial number: 23061713471041
Coding: 01
ASAM Dataset: EV_LWSKLOVW25X 005001
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA5FCF6707B8B3B01E-802A
Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb
Part No SW: 7E0 907 047 AC HW: 7E0 907 047 AC
Component: Climatic-T5 H22 0708
Revision: 00001002
Coding: 0000000003
ASAM Dataset: EV_ClimaticT5 A01003
ROD: EV_ClimaT5Basis.rod
VCID: 6B83C5A213090E93B60-803E
Address 09: Cent. Elect. (J519) Labels:. 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 C HW: 7E0 937 090 C
Component: BCM PQ25 Max4 H82 0752
Revision: B9082001 Serial number: 4000 172170185
Coding: B8FC793A4AF3341393284F607CEB9FFCC094738960CD79E03304003F0860
Shop #: WSC 02737 022 144021
VCID: 2B0305A2D309CE93F60-807E
Subsystem 1 - Part No: 5K7 955 559 C Labels: 5K7-955-559.CLB
Component: RLS 220617 04 42 0106
Coding: 008F77
Subsystem 2 - Part No SW: 7E0 959 801 R HW: 7E0 959 801 R Labels: 7E0-959-80X-V2.CLB
Component: J386__TSG_FT 004 0653
Serial number: KU0KU026061771773104
Coding: 1400B1
Subsystem 3 - Part No SW: 7E0 959 802 Q HW: 7E0 959 802 Q Labels: 7E0-959-80X-V2.CLB
Component: J387__TSG_BT 003 0653
Serial number: KU0KU014061771656809
Coding: 0400A1
Subsystem 4 - Part No: 7E1 951 172
Component: DWA-Sensor 00 001 0104
Coding: 000000
Subsystem 5 - Part No: 1K0 951 605 F
Component: LIN BACKUP HO H01 0008
Coding: 000000
Subsystem 6 - Part No: 7E1 951 172
Coding: 000000
Subsystem 7 - Part No SW: 7E0 959 442 HW: 7E0 959 442 Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H02 0103
Serial number: 29170001388390027255
Coding: B0FFFF
6 Faults Found:
03434 - Output for Terminal 30G Interior Lights
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 3
Fault Frequency: 2
Reset counter: 1
Mileage: 47697 km
Time Indication: 0
Date: 2020.12.01
Time: 05:09:21
03435 - Terminal 30 for Interior Light and Parking Light
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 1
Mileage: 47697 km
Time Indication: 0
Date: 2020.12.01
Time: 05:10:09
01520 - Rain and Light Recognition Sensor (G397)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 26
Mileage: 48258 km
Time Indication: 0
Date: 2020.12.11
Time: 14:12:49
02745 - Bulb for Daytime Running Light; Left
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 1
Mileage: 47697 km
Time Indication: 0
Date: 2020.12.01
Time: 05:10:14
02746 - Bulb for Daytime Running Light; Right
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 1
Mileage: 47697 km
Time Indication: 0
Date: 2020.12.01
Time: 05:10:14
04194 - Vehicle Status with Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 6
Mileage: 47697 km
Time Indication: 0
Date: 2020.12.01
Time: 05:07:15
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 AA HW: 7N0 919 475
Component: PARKHILFE 8K H06 0212
Revision: -------- Serial number: 28231715102088
Coding: 30810C
ASAM Dataset: EV_VW75XParkAssis8K 001012
ROD: EV_VW75XParkAssis8K_001_VN75.rod
VCID: 71BFD7CA3125E4438CC-8024
Address 13: Auto Dist. Reg (J428) Labels:| 7N0-907-572.clb
Part No SW: 7N0 907 572 C HW: 7E0 907 572
Component: ACC Bosch PQx H03 0211
Serial number: 2106170440A216
Coding: 00005000FE0779
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_ACCBEGVW361 001006
ROD: EV_ACCBEGVW361.rod
VCID: 363524D618CB837B99E-8062
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 7E0 959 655 H HW: 7E0 959 655 H
Component: VW10Airbag01S H08 0018
Revision: -------- Serial number: 003V400354EL
Coding: 000000000000000000000000000000003153
Shop #: WSC 02734 790 50316
ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 3B2335E223E95E13660-806E
Crash sensor for side airbag: driver side:
Serial number: 3495ZRB400K59OGCJ8EA
Front Passenger's Side Airbag Crash Sensor:
Serial number: 3505ZRB400K59OGCHPRU
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 7E0 920 970 S HW: 7E0 920 970 S
Component: KOMBI H03 1107
Serial number: 00000000000000
Coding: 140F010300
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733
ROD: EV_Kombi_UDS_VDD_RM09_005_VW25.rod
VCID: 3A2D30E62CD3671B7D6-806E
Address 19: CAN Gateway (J533) Labels:. 7E0-909-901.clb
Part No SW: 7E0 909 901 HW: 7E0 937 090 C
Component: GW-K-CAN TP20 H82 0752
Revision: B9082001
Coding: 042307
VCID: 6889BAAE027F258BDB2-803C
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H03 1107
Serial number:
Coding: 000000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
ROD: EV_Immo_UDS_VDD_RM09_VW23.rod
VCID: 6A8DC0A61CF3179BCD6-803E
1 Fault Found:
9456128 - Engine Control Module (ECM) not authorized
B104A 00 [008] - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 254
Mileage: 47697 km
Date: 2020.12.01
Time: 05:11:49
Address 55: Headlight Range (J431) Labels:. 6R0-907-357.clb
Part No SW: 6R0 907 357 C HW: 6R0 907 357 B
Component: AFS-ECU 005 0050
Revision: -------- Serial number: --------------
Coding: 0FCE020001000000
Shop #: WSC 02757 790 50316
ASAM Dataset: EV_HeadlRegulVWLWRCC 002006
ROD: EV_HeadlRegulVWLWRCC.rod
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb
Part No SW: 5C0 035 680 G HW: 5C0 035 680 G
Component: MU-S-ND-ER H41 0468
Serial number: VWZAZ2T5275199
Coding: 06570001FF00000011111101008808001F0100C6002001004F
ASAM Dataset: EV_MUStd4CTSAT 001022
ROD: EV_MUStd4CTSAT_VW32.rod
VCID: 2517F39AB56DF8E3204-8070
Data carrier:
Subsystem 1 - Part No SW: 5NA 919 866 HW: -----------
Component: ECE1 2018/19 --- 1030
Serial number: --------------------
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 7E0 907 534 HW: 7E0 937 090 C
Component: Batt.regelung H82 0752
Coding: 330B1A73
Shop #: WSC 56937 003 1048576
Subsystem 1 - Part No SW: 7E0 915 181 K HW: 7E0 915 181 K
Component: J367-BDMConti H03 1050
Serial number: 75885700001706200895
1 Fault Found:
02256 - Quiescent Current
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 7
Fault Frequency: 11
Reset counter: 32
Mileage: 0 km
Time Indication: 0
Date: 2020.12.01
Time: 12:21:07
Address 6C: Back-up Cam. (J772) Labels:| 5Q0-907-441.clb
Part No SW: 7N0 907 441 B HW: 7N0 907 441 B
Component: VW428 RVC Mid H04 0040
Coding: 011300012A01000300
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_CamSysRearPANAVW428 002002
ROD: EV_CamSysRearPANAVW428.rod
VCID: 303912CEFAAFAD4BC32-8064
1 Fault Found:
10489856 - No Basic Setting
B2010 00 [009] - -
[RearView system not calibrated]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 217
passive
End----------(Elapsed Time: 02:01, VBatt start/end: 12.1V/12.1V)-----------
