Thursday,13,July,2023,10:19:16:01985
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 23.3.1.0 (x64) HEX-NET CB: 0.4631.4
Data version: 20230421 DS346.2
www.Ross-Tech.com
Workshop Code: 123 12345 012345
VIN: WVWZZZ7NZDV024587 License Plate: SHRN2013
Mileage: 49170km-30552mi Repair Order: 230713
Chassis Type: 7N-VW36 (7N0)
Scan: 01 02 03 05 08 09 10 14 15 16 17 18 19 20 25 2B 36 3C 42 44
46 47 4C 4F 52 53 55 5F 61 62 65 6C 6D 72 A5 B9 BE BF
VIN: WVWZZZ7NZDV024587 Mileage: 49170km-30552miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
14-Susp. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
18-Aux. Heat -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
20-High Beam Assist. -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
36-Seat Mem. Drvr -- Status: Malfunction 0010
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4C-Tire Pressure II -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
B9-Aux. Display -- Status: OK 0000
BE-Slid. Door Rear Left -- Status: OK 0000
BF-Slid. Door Rear Right -- Status: OK 0000
Address 01: Engine (CCZ) Labels:. 06J-907-115-CCZ.clb
Part No SW: 06J 906 027 DJ HW: 06J 907 309 A
Component: MED17.5.2 06 2269
Revision: P3H07--- Serial number:
Coding: 0404000C1C170160
Shop #: WSC 00020 790 12345
VCID: 76A0EAE901C0FC23E1-8022
VINID: 9E69EAAAA1DEA949800841481C276FDCB1
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 058 T HW: 02E 927 770 AL
Component: GSG DSG AG6 512 3515
Revision: 05651213 Serial number: 00001211151749
Coding: 0000020
Shop #: WSC 00020 000 90108
VCID: 2B160B9D8A02F1CB4E-807E
Address 03: ABS Brakes Labels: 7N0-614-109.clb
Part No SW: 7N0 614 109 P HW: 7N0 614 109 P
Component: J104 C3 450M VD9D 0030
Revision: --H07--- Serial number: 00000006425793
Coding: 0003896
Shop #: WSC 00020 790 00000
VCID: 3A383ED975585843C5-806E
Address 05: Acc/Start Auth. (J518) Labels:| 5K0-959-434.clb
Part No SW: 5K0 959 434 F HW: 5K0 959 434
Component: VWKESSYPQ35GP 093 1202
Revision: 00093000 Serial number: 0344538672 Dataset Number: V03935246WW 0001
Coding: 13100C
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_KESSYPQ35G A02717
ROD: EV_KESSYPQ35G_A02_VW31.rod
VCID: 383C24D183544A5333-806C
Address 08: Auto HVAC (J255) Labels:| 5K0-907-044.clb
Part No SW: 7N0 907 044 F HW: 7N0 907 044 F
Component: Clima-Sharan H01 0202
Revision: 00001K03
Coding: 0218104548
ASAM Dataset: EV_ClimatronicSharan A01005
ROD: EV_ClimaAutoSharaBasis.rod
VCID: 332613FD9A32A90B06-8066
Slave 1:
Subsystem 1 - Part No SW: 3AD 907 049 A HW: 3AD 907 049 A
Component: KBT-H H09 0020
Serial number: CG11068266
Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
Part No SW: 5K0 937 086 M HW: 5K0 937 086 M
Component: BCM PQ35 M 021 0068
Revision: BC021001
Coding: 465F0ABFEC2B27C4808834C9B10089EC47FD00086F71ADB0E48C4024A2C1
VCID: 3E3032C9A9707463F9-806A
Subsystem 1 - Part No SW: 7N2 955 119 A HW: 7N2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 121015 31 0032
Serial number: 121024214914
Coding: 004DBD
Subsystem 2 - Part No SW: 5Q0 955 547 HW: 5Q0 955 547 Labels: 5Q0-955-547.CLB
Component: RLFS 024 0042
Serial number: Y12M11D27H21M39S02S4
Coding: 068885
Subsystem 3 - Part No: 7N0 951 171
Component: DWA-Sensor 00 002 0205
Coding: 000000
Subsystem 4 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Coding: 000000
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-298.clb
Part No SW: 1K8 919 475 B HW: 5Q0 919 298
Component: PARKHILFE PLA H12 0479
Revision: -------- Serial number: 39491531403690
Coding: 0121267011
ASAM Dataset: EV_EPHVA2CVW364GP00 001010
ROD: EV_EPHVA2CVW364GP00.rod
VCID: 393A21D5B85E535BCC-806C
Address 14: Susp. Elect. (J250) Labels:. 3C0-907-376.clb
Part No SW: 3C0 907 376 A HW: 3C0 907 376
Component: DAEMPFUNGS-SG H07 0071
Revision: 00000000 Serial number: 16111202720002
Coding: 010180
VCID: 271EF7AD56EAD5ABAA-8072
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 7N0 959 655 C HW: 7N0 959 655 C
Component: VW10Airbag00M H11 0014
Serial number: 003LGPQ8V001 Dataset Number: 7N0003v____ 0289
Coding: 00304D
Shop #: WSC 00020 999 00000
ASAM Dataset: EV_AirbaVW10TS6VW428 A01004
ROD: EV_AirbaVW10TS6VW428.rod
VCID: 3FCE4FCDA67A7D6BF2-806A
Crash sensor for side airbag: driver side:
Subsystem 1 - Part No SW: --- HW: ---
Component: S.Sens.Fahr.V --- ---
Serial number: 3493ETS60E09C11179DY
Coding: 000000
Front Passenger's Side Airbag Crash Sensor:
Subsystem 2 - Part No SW: --- HW: ---
Component: S.Sens.Beif.V --- ---
Serial number: 3503ETS607C8D1E179D1
Coding: 000000
Rear Side Airbag Crash Sensor (on driver's side):
Subsystem 3 - Part No SW: --- HW: ---
Component: S.Sens.Fahr.H --- ---
Serial number: 3513ETS60BD9C1117DD+
Coding: 000000
Passenger side rear thorax airbag crash sensor:
Subsystem 4 - Part No SW: --- HW: ---
Component: S.Sens.Beif.H --- ---
Serial number: 3523ETS6081641E179DP
Coding: 000000
Crash sensor for front airbag: driver side:
Subsystem 5 - Part No SW: --- HW: ---
Component: F.Sens.Fahr --- ---
Serial number: 35540TS609E1FE616DD0
Coding: 000000
Address 16: Steering wheel (J527) Labels:| 5K0-953-569.clb
Part No SW: 5K0 953 521 CM HW: 5K0 953 569 E
Component: LENKS.MODUL 014 0140
Revision: FF010041 Serial number: 20121116100931
Coding: 301A240008
ASAM Dataset: EV_SMLSNGVOLWSXS A01004
ROD: EV_SMLSNGVOLWS.rod
VCID: 79BAE1D5F8DE935B8C-802C
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 5NA 959 442 B HW: 5NA 959 442 B
Component: E221__MFL-TAT H06 0025
Coding: 2D0000
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 7N0 920 880 K HW: 7N0 920 880 K
Component: KOMBI H05 1114
Serial number: 00000000000000
Coding: 111D030000
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733
ROD: EV_Kombi_UDS_VDD_RM09_005_VW25.rod
VCID: 3B363BDDB262614BDE-806E
Address 18: Aux. Heat Labels: 1K0-815-071.clb
Part No: 5K0 963 271 B
Component: Zuheizer 051 2706
Revision: 00051000 Serial number: 09021535000000
Coding: 0000001
VCID: 2E100289B91084E369-807A
Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 BC HW: 7N0 907 530 AN
Component: J533 Gateway H56 1663
Revision: H56 Serial number: 15101500F11091
Coding: 358023
VCID: 72A8D6F9ADA8E003CD-8026
Address 20: High Beam Assist. (J844) Labels:| 8S0-857-511.clb
Part No SW: 7E0 857 511 F HW: 7E0 857 511 C
Component: FLA H10 0003
Revision: AA001001
Coding: 0202010300000000000002
ASAM Dataset: EV_HighBeamAssisAU316 001004
ROD: EV_HighBeamAssisAU316.rod
VCID: 2D1205857C16FFFB50-8078
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H05 1114
Coding: 000007
Shop #: WSC 00046 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
VCID: 6A98CE998D7828C375-803E
Address 2B: Steer. Col. Lock (J764) Labels:* 5K0-905-861.clb
Part No SW: 5K0 905 861 B HW: 5K0 905 861 B
Component: ELV-PQ35 H20 0240
Revision: 00000000 Serial number: 12000263247003
Coding: 4900000000000000
ASAM Dataset: EV_ELVMarquMPVW36X A01001
ROD: EV_ELVMarquMPVW36X.rod
VCID: 2F2E1F8D761A8DEB62-807A
Address 36: Seat Mem. Drvr Labels: 3C0-959-760.lbl
Part No SW: 3C0 959 760 B HW: 3C0 959 760 B
Component: Sitzverstellung 0701
Revision: 00003000 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 2C1408818F0CF6F347-8078
5 Faults Found:
02327 - Position Sensor for Front Seat Height Adjustment (G438)
011 - Open Circuit
02328 - Position Sensor for Rear Seat Height Adjustment (G439)
011 - Open Circuit
01916 - Lumbar Support Fore / Aft Adjustment Sensor (G375)
011 - Open Circuit
01915 - Lumbar Support Height Adjustment Sensor (G374)
011 - Open Circuit
01330 - Central Control Module for Central Convenience (J393)
004 - No Signal/Communication
Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
Part No SW: 5Q0 907 686 C HW: 5Q0 907 686 C
Component: HRE_Master H12 0081
Serial number: 0495886885 Dataset Number: V03935258DF 0001
Coding: 03031202
ASAM Dataset: EV_HREntryHella 001028
ROD: EV_HREntryHella_VW32.rod
VCID: 3D3235C5AC766F7BE0-8068
Lane change assistance control module 2:
Subsystem 1 - Part No SW: 5Q0 907 685 C HW: 5Q0 907 685 C
Component: HRE_Slave H12 0081
Serial number: 0503974197
Coding: 030312
Address 42: Door Elect, Driver (J386) Labels:. 7N0-959-793.clb
Part No SW: 7N0 959 793 G HW: 7N0 959 793 G
Component: TSG FA H03 0553
Revision: Serial number: 0000044585295
Coding: 011D1620D201411011
VCID: 46C05A29F1A02CA3B1-8012
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 7N0 909 144 P
Component: EPS_ZFLS Kl. 274 3305
Revision: 00H21000
VCID: 40CC4C31138402938B-8014
Address 47: Sound System (R12) Labels: 5K0-035-456.clb
Part No SW: 5K0 035 456 C HW: 5K0 035 456 C
Component: KonzernAmp 8K H07 0202
Revision: -------- Serial number: EAA086A0026825 Dataset Number: 1K8050v____ 7N02
ASAM Dataset: EV_AudioVerst8KanalBNO1 A01003
ROD: EV_AudioVerst8KanalBNO1.rod
VCID: 2A180E994DF8E8C3B5-807E
Address 4F: Centr. Electr. II (J520) Labels:. 1K0-907-532.clb
Part No SW: 7N0 907 532 HW: 7N0 907 530 AN
Component: EZE_2 H56 1663
Coding: 05030100
VCID: 6FAEDF8DBE9ACDEB22-803A
Subsystem 1 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H04 0220
Serial number: 0123456789ABCDEFGHIJ
Subsystem 2 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J394EE20SKB13 H04 0220
Address 52: Door Elect, Pass. (J387) Labels:. 7N0-959-792.clb
Part No SW: 7N0 959 792 G HW: 7N0 959 792 G
Component: TSG BF H03 0553
Revision: Serial number: 0000044559479
Coding: 011D16205E01410011
VCID: 45C25D25CCA627BBB8-8010
Address 53: Parking Brake Labels: 3AA-907-801.clb
Part No SW: 3AA 907 801 H HW: 3AA 907 801 H
Component: J540 EPB4 VW-86594 0010
Revision: H19 Serial number: 00000000605996
Coding: 0024157
VCID: 36202AE94140BC2321-8062
Address 55: Headlight Range (J745) Labels:. 5M0-907-357-V3.clb
Part No SW: 5M0 907 357 F HW: 7L6 907 357 C
Component: AFS-ECU H04 0111
Revision: -------- Serial number: -------------- Dataset Number: 7N005Mv____ 0F01
Coding: 053200000B000200
ASAM Dataset: EV_HeadlRegulVWAFSPt 002016
ROD: EV_HeadlRegulVWAFSPt_VW32.rod
VCID: 373E27ED8E4A452B3A-8062
Left_headlamp_power_output_stage:
Subsystem 1 - Part No: 1T0 941 329 Labels: 3D0-941-329.CLB
Right_headlamp_power_output_stage:
Subsystem 2 - Part No: 1T0 941 329 Labels: 3D0-941-329.CLB
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb
Part No SW: 5K7 035 200 H HW: 5K7 035 200 H
Component: MU-S--ROA H31 0367
Serial number: VWZAZ2S5325164 Dataset Number: V03935249AS 0001
Coding: 02240800FF0000000111000600090021DF0100C70100010000
ASAM Dataset: EV_MUStd4CTSAT 001022
ROD: EV_MUStd4CTSAT_VW32.rod
VCID: 291AF19548FEE3DBBC-807C
1 Fault Found:
15360768 - Component Protection
U1101 00 [009] - Active
[Anti-theft protection - component protection active (0xEA6300)]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 157
Mileage: 49176 km
Date: 2023.07.13
Time: 10:14:26
Voltage terminal 30: 12.4 V
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 7N0 907 534 HW: 7N0 907 530 AN
Component: Batt.regelung H56 1663
Coding: 02240876
VCID: 71AAD9F5A8AEDB1B34-8024
Subsystem 1 - Part No SW: 1K0 915 181 H HW: 1K0 915 181 A
Component: J367-BDM H07 0180
Serial number: 00000000001490726965
Address 62: Door, Rear Left (J388) Labels:. 7N0-959-794.clb
Part No SW: 7N0 959 794 H HW: 7N0 959 794 H
Component: TSG HL H01 0553
Revision: Serial number: 0000131364399
Coding: 01006C200001411001
VCID: 48DC5411FBB43AD343-801C
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 3AA 907 273 F HW: 5Q0 907 273
Component: RDKBERU30 H06 0011
Serial number: 40000000451190 Dataset Number: rdkseditor 0204
ASAM Dataset: EV_RDKBERU30 005005
ROD: EV_RDKBERU30_005.rod
Address 6C: Back-up Cam. (J772) Labels:| 5Q0-907-441.clb
Part No SW: 7N0 907 441 B HW: 7N0 907 441 B
Component: VW428 RVC Mid H04 0040
Dataset Number: V03935251ED 0001
Coding: 012408012A01000700
ASAM Dataset: EV_CamSysRearPANAVW428 002002
ROD: EV_CamSysRearPANAVW428.rod
VCID: 302C1CF16B2492137B-8064
Address 6D: Trunk Elect. (----) Labels:| 7N0-959-107.clb
Part No SW: 7N0 959 107 E HW: 7N0 959 107 A
Component: HDSG-Modul H11 0243
Revision: 41011001 Serial number: 297200524 Dataset Number: 7N0959107E D016
Coding: 0733334002
ASAM Dataset: EV_HDSGVW428 201138
ROD: EV_HDSGVW428_VW36.rod
Address 72: Door, Rear Right (J389) Labels:. 7N0-959-794.clb
Component: TSG HR H01 0553
Revision: Serial number: 0000131364461
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 3Q0-980-65X-A5.clb
Part No SW: 3Q0 980 654 Q HW: 3Q0 980 654 A
Component: MQB_B_MFK H12 0881
Serial number: 09071912P22848 Dataset Number: V03935303EU 0001
Coding: 000402080000030500060052C0878000DB000E10000000
Shop #: WSC 00046 123 12345
ASAM Dataset: EV_MFKBoschMQBB 002041
ROD: EV_MFKBoschMQBB_002.rod
VCID: 45C25D25C4A627BBB8-8010
Address B9: Aux. Display (J285) Labels:* 5C5-919-527.clb
Part No SW: 1K8 919 527 B HW: 1K8 919 527 B
Component: ZUSATZANZEIGE H08 0003
Coding: 05
ASAM Dataset: EV_Auxi_Disp_Unit_UDS_VDD 001010
ROD: EV_Auxi_Disp_Unit_UDS_VDD.rod
Address BE: Slid. Door Rear Left (J558) Labels: 7N0-959-244.clb
Part No SW: 7N0 959 244 A HW: 7N0 959 244 A
Component: Schiebetuer_l 005 2314
Serial number: 12457609
ASAM Dataset: EV_AST A03704
ROD: EV_AST.rod
Address BF: Slid. Door Rear Right (J731) Labels: 7N0-959-244.clb
Component: Schiebetuer_r 005 2314
Serial number: 12457614
ROD: EV_AST.rod
End----------(Elapsed Time: 02:26, VBatt start/end: 12.7V/12.7V)-----------
