PM'd yaBy the way where did you get your kit from?
And how much was it, if you don't mind me asking?
You can activate all of these but their effective functionality will be achieved once PLA is onboard and that is completely different story(retrofit).what do you recon, both ticked, or none ticked
Sharan 7N / Alhambra 71 should be the best choice in this scenario.
It's working without... Not sure I really need too, tested this evening on my drive way reversing on and it's preety spot on where the lines are and wheels run so I might just leave it...Are you going to complete calibration then?
I have to admit that I was wrong.Okay, I found inexpensive source of all required components(brand new components) and now I am awaiting my delivery.
It looks that I am going to close the whole upgrade within £100 = €112.
More details soon.
Watch this space.
I got my missing parameterization file.I have installed my new module last night.
It is truly a very simple and a very quick procedure.
One hour including cup of warm tea.
I took number of photos so I will try to upload them later on.
New module needs to be connected to CONVENIENCE CAN BUS( and power supply).
Quick check with VCDS and my brand new module is missing parametrization.
A real virgin!
Lack of data set prevents coding modification and then without proper coding, the calibration can't be completed.
I wasn't prepared for that so now I need to get my XML or ZDC file to get the software side finished.
I want to ask @Robert, @dnoermann and @mmi about their opinion, there are some VWs and Skodas, which have Area View system, in which the reverse camera is with dynamic lines. Browsing through ETKA, I only managed to find 2 types of cameras, one with ordinary 2 pin FAKRA connector and additional CAN and power connector, which has dynamic lines and eventual Trailer Assist, PR Code - KA2. The other one, which is with 4 pin HSD connector and LVDS signal and PR Code - KA6?! And there is, of course, the simplest of the cameras with static lines, PR Code - KA1, but it's not related to Area View system!
I believe this is better location to answer your question.judasfan said:Hell Robert, thank you very much for having me, I suppose it is OK to call you by your first name?
I am expecting delivery of my T6.1 van, which will be loaded with much extras, but due to a conflict in configuration of some options, it will not have rear view camera. I will add the camera, when I get the van. As I told you, I am following the thread for Area View retrofit and I was wondering how some VW and Skoda vehicles have Area View rear cameras, together with dynamic lines? My research so far, which may not be exact, is that the cameras for Area View and dynamic lines are different!
Disabled? Not enabled?its all sorted...
i had it all programmed correctly part from ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B had to be disabled in my instance.
once that was changed, ignition off, keys out for 30secs and then a reboot of the head unit. all works great and the moving guidelines work too.
