Remember that the vans are all the same chassis underneath
, the difference between T 26 T 28 T 30 and T 32 is simply the suspension roll bars and brakes .
the only difference on the T 32 shock is the lower mounting bracket in reality . Its just a bracket and doesn't change the ride or handling characteristics from one van to another .
Very few after market kits can actually carry a ton load , but then if you want to carry a ton dont fit after market suspension and keep it as a work horse !!
A T32 204 hp DSG is a little heavier than most vans and weight makes them more comfortable anyway .
Hi Steve Can I ask you a question please to see a 3 ton van can get a 3.2 T lifting kit installed.
I was ordering a new Transporter 6.1 3.2 4motion LWB with all the bell and whistles.
Then having a Koni lift kit installed and then a complete camper conversion done as soon it arrives.
However, just looking at your comments above I was told from a very well known VW camper Conversion dealer in Sydney Austrilia who says he worked on VW in England before coming down under. He said there is no difference between the VW Transporter 6.1 chassis for a T3 & T3.2 therefore he said, why would you waste your money buying a T3.2 van if I was going to add a lifting Kit. (My preference was based on a T3.2 was the higher GVM weight).
He said he will install a Koni Lifting kit to a T3 ton van so it will be a T3.2 GVM weight with it will cost me an extra $500 to register the van as a T3.2 along with an Engineered Certified Certificate for insurance.
I think the T3.2 van comes with strong stabilizer bars and the Koni Kit also comes with Strong Stablizer bars and also, allows for lowering kit for the drive shaft.
Anyway, do you think this guy is correct with what he can do.
Do you see that this is possiable that a 3 ton van and have a Koni coilover system be successfully installed to be a T3.2. and if so, will it be a comfortable ride due to my future ambitions is to turn this van into a swampy, and travel on city roads, corrugate roads, off road tracks, along beachs all around Australia.
Or do you think it is best just revert my VW order back to a T3.2 before its two late.
When ordering a T3.2 from over hear you don`t recieve a spare wheel, you instead receive a puncher kit and compressor. No good if you`re out in the desert and get a flat or rip the rubber off the tyer.
So it an extra cost to purchase a spare wheel & tyer and the bracket to hold the spare wheel in its compartment so, you up for that as well, and you dont get a car jack either so, I`m up for that $1300 if you buy them new.
I hope you don`t mind answering my question as it also frastrating that there isn't any experts over here to answer my questions, and boy have I tried.
Really appreciate your comments and view.
Cheers.
Garry from down under.
