My post above is the 'news' that Pauly was referring toDo you know if there has been any update on this issue yet, thanks
Just to explain a bit more as it wasnt clear earlier
When @Baloo took his van back with the symptons others were/are experiencing of the vehicle dying going downhill off the throttle VW computers found a fault logged in the vehicle (which it seems is not present in others) and they did not want it driven and kept hold of it and left him with a courtesy van. From memory the fault was in a particular control module but i cant remember which one (hopefully @Baloo can remember)
His vehicle was requested back to the factory in Germany for inspection/testing so VW could look into the problem, from this info i took it a fix would be coming in due course when they had completed diagnosis
I think my earlier post was worded badly and i may have filled you with false hope, apologies if i misled you.
Yes, I certainly got the impression they’d all been located, I know I was the first one to have a replacement van.I would assume these 10 vans should/would have been tracked by now ?, or are there any underlying faults relating to this issue....
The cutting-out issue has happened to both me and my wife on several occasions, most recently yesterday. In the past it has mostly been travelling onto a roundabout and when merging at approx 20mph. It seems to be triggered by gear change from maybe 2nd into 3rd at lowish rpm's (moving into 3rd at maybe just over 1k rpm). The engine isn't stalling as such, it just dies. Sometimes it can be restarted by 'bumping' it in gear, but this is not always the case.
Yesterday was the worst so far, driving into a left hand turn at around 25mph and again changing gear mid turn only for engine to die and loss of power steering. My driving style may be adding to the symptoms but have never had this issue in the past with any of my other vehicles.
The immediate loss of power steering is a major issue especially mid turn. I would imagine some women would really struggle to overcome the resistance on the steering wheelAll sounds very similar to how it happened to me, so so worrying if it happens while the mrs is driving, not sure at all how she would react.
Have done the same here with stop start, not happened since.Happened again yesterday, turning left into a side street, around 15mph in 3rd gear about to change into 2nd gear, engine died no power steering, re started after second dip of clutch..
Had VW assist out today no fault found but have been advised to drive with start stop off for a few weeks to see if problem reoccurs, if not then try again leaving start stop on, we will see!!!
