Sounds like you waited too long to change to 3rd and revs dropped too low and engine stalled. If you had dipped the clutch quickly at the point of total cut out it should have started straight away on its own. Once engine cuts out power steering can go. I had this happen on an island where I was in wrong gear. Scary stuff though.I've started this thread because it seems to be a different issue to one already posted, where the engine dies at low speed.
Just had the biggest scare of my life- going down a steep'ish hill, with a 90 degree bend at the bottom. Doing about 35mph in 4th gear. I started to change down to 3rd, and the engine died, with the loss of the power steering. Had it all on to navigate the bend and ended up on the grass verge.
I released the clutch in 3rd as it was slowing and it was dead. Once stationary i turned the ignition of, back on and it restarted normally, no warning lights, and didnt do it again on the way home.
It was pretty scary tbh. If the wife had been driving, it would have ended up in a ditch, without doubt. Will contact the dealer on Mon, but i am dreading the "no fault found" answer after a day wasted.
It is also affected by atmosphere outside vehicle and temp. No set rules about when it will come on or cut out as depends on lots of factors. The ECU will know when it's able to do this.Its hit and miss, my van will generally not stop/start with AC running but if the engines warm on a decent run (and i assume the battery is fully charged) then it will stop start if only on low fan speed as above
Anything that places excessive electrical load on the alternator will cause the S/S system to disable this includes A/C, heated screens, heated mirrors, heated seats etc and any aftermarket kit connected to van battery (not leisure battery) like invertors or chargers
Hi,
I just found this website when I was looking for more information to understand what happened to my van this weekend. We picked up our new California Beach 150 HP manual a week ago and went for our first long drive this weekend (living in Vienna by the way). We experienced exactly the same what happened to TEESIXY and others this weekend. Complete engine shut down when making a (over) 90 degree bend with the loss of the power steerin while shifting down from 6th to 3rd gear! Scary stuff, fortunately we did not end up in a ditch or something. The next day I twice experienced an engine shot down while going at low speed but without power steering loss (I think). I assume this must be related. Following suggestions in the forum I will call VW assistance and report the issue. I will also bring back the van to the dealer for a thorough check. I was wondering if the issue has been solved by others who experienced this. Thanks!
It also happened to me sometimes ... manual 150cv ... when it releases the accelerator at low speed ... the bad thing is that the steering does not work ..... it 's really a shit the' electronics of this engine ...
