I run the Renogy 2kw inverter in the van .... It's faultless and runs stuff others won't.I keep trying to justify getting a 2kw inverter as that would complete the set!![]()
Hi Dell, Do you know if the Renogy 2000w inverter will fit in a single seat base. I have 2 single seats up front and was thinking of putting a 230 Roamer battery under the passenger seat and a Renogy 50 amp DC-DC charger and Renogy 2000w inverter under the drivers seat hopefully leaving enough room for a heater outlet at the back of the drivers seat base when i eventually get round to fitting an external Diesel night heater. If not, do you know of any 2000w inverter that will fit?? Thanks in advance for any adviceI've had the 2kw Renogy unit.
It was used for the massive battery box.
200Ah, 2000W, LifePo4 Leisure Battery Box -- How I Done It --
200Ah, 2000W, LifePo4 Leisure Battery Box -- How I Done It -- Its Spring 2022 and time to look ahead at the summer camping season. having a look over the new products that have come to market over the last 12mnths, especially the Lithium based battery boxes i was liking what i was seeing...www.t6forum.com
But was quickly made redundant after getting the 2kw Bluetti and EF Delta2.
So sold it to @Eli
(Who was planning to run it hot plugged into his T6 when camping)
Extend the panel leads with 6.00mm2 and put the MPPT charger near to the leisure battery, I've got an isolator in the wardrobe where my solar tails come through.Hello electric experts.
Can I have my MPPT at the back of the van where the factory cables off the solar panel will end and then run a cable to the LB under the driver seat or is it better to extend the factory solar cables to the controller under the seat base and then have a shorter run to the LB?
Planning a 200W photonic universe semi flexible panel with Victron Smart 75/15 to charge a 110Ah FLA battery which will run the usual fridge, lights, USB etc. Panel comes with 3m of factory 4mm cable.
Panel is being fitted by the guys doing our pop top roof next month so I'd like to run cables before they carpet the roof rails. Would more 4mm cable be okay or should it be 6mm to allow for voltage drop on the way to front of van?
Thanks.
Not sure if your panels are the same but typically they seem to come with a short lead and a long lead with the short lead being too short to actually get inside the van without being extended.
Yes, never simple, but after looking at builds and requirments, will it just be a case of putting the DC-DC where the VSR was?A euro 6 T6 will have the smart alternator and the nonsense that goes with that meaning a battery to battery charger rather than the earlier Durite VSR setup.
Aye, any DC to DC will do the job. I have the Renogy DCC50S but the DCC30S is actually sufficient for my current needs.There's some excellent builds there.
After removing my system from my T4, Durite VSR, I'm wondering if all i need to replace is the VSR, replacing with a DC-DC?
After several years of use, i found no requirements for Solar or EHU, would the old system still be suitable for a T6? I am only ever using 12v LED lighting, USB Ports and a 12v Cigar style socket every now and again?! *May add diesel heater or propex heater into build.
Starter Batt > (under seat) DC-DC > Leisure Batt > Blade Fuse Box > Switches > Devices? (with relevant inline fuses in place along the way)
Any advice greatly received.
J
Thanks,Aye, any DC to DC will do the job. I have the Renogy DCC50S but the DCC30S is actually sufficient for my current needs.
You get a nice App for your phone,which shows the charge state and history.
Have a look at the How I Did It, on the other thread for lots of advice and helpful hints.
