Load output +ve to Votronic l (BORD).Deak's can ya share the MPPT load output/voltronic standby circuit diagram please?
many thanks
Ha not enough
thank you !!
stu
Votronic ll (START) to Starter battery +ve
the -ve connections on the Victron MPPT are common so no need to connect this
then configure the load output to switch on at a set battery voltage eg when your LB is full
