235/65/17 Falken Wildpeak AT3waLovely- what tyres are you putting on
Nice - will look great- look forward to pics when on235/65/17 Falken Wildpeak AT3wa
Those look lovely mate. I'm torn between them and the Mac-at'sAfter months of trying to decide, they're finally on.
Navis Gelida AT Satin Black 17"
Falken Wildpeak AT3WA 235/65/17
Standard suspension
Hi,Here are my Satin Black Devonports
Falken Wildpeaks 235/65/17
Standard suspension T32 4motion
Much improved ride
View attachment 242264View attachment 242265View attachment 242266
that looks a great set up, did you use spacers on your Devonports, or does the wide tyre just fill the arch out better?Here are my Satin Black Devonports
Much improved ride
Just standard set up with no spacers - if I was to be picky you could space out the rear maybe 15mmHi,
Great, thank you.Just standard set up with no spacers - if I was to be picky you could space out the rear maybe 15mm
Looks great - have you noticed much change to the speedo as a result of fitting the 235 65 tyre?
It now reads correctly and matches sat nav!Looks great - have you noticed much change to the speedo as a result of fitting the 235 65 tyre?
Wow - that's useful. Thank you.It now reads correctly and matches sat nav!
My Speedo is pretty good Maybe 1mph out compared to sat nav but my mpg reading won’t go over 36 mpg where as before it would go to 41/42mpg.It now reads correctly and matches sat nav
235 or 245/65/17 bfg? Didn’t no bfg did a 235/65/17Hi have BFG 235/65/17 with 35mm drop on KW v3s no problems
Is that mat black they look glossy in the pictureLovely- what tyres are you putting on
How have you found the Wildpeaks in that size? Do you have any other photos at all?Sort of snap!
Brand new Kato's with Falken Wildpeak AT 225/65/R17
Absolutely brilliant, quiet on road and grippy the couple of times I’ve been on slippery stuff. Real go-anywhere tires and and great value imho.How have you found the Wildpeaks in that size? Do you have any other photos at all?
Can I please ask what size tyres you have fitted?View attachment 2487448x17 DV8 Verve
No problem the Tyres are 235/65R17 .Can I please ask what size tyres you have fitted?
