Nice job with the mud flaps. I did nt suppose you have a link to where your lower trim and mudflaps came from? I made a bit of a mistake with the offset on my wheels and they stick out a bit too far and throw mud everywhere.Finally!!!
Mudflaps fitted. Will clean the plastics and treat them with Concept Vista on Monday
View attachment 257240View attachment 257239
A very practical and useful 4Motion. For work, rest and play. Plenty of lights for the long dark nights, are they all https://www.lazerlamps.com ? I imagine that lot would turn night into day. Even seeing behind for reversing. What do you use the work lights mounted close to the door mirrors for?Hellou from Finland
Here is my swamper. Works is in process as always, but I'm happy with this situation anyway.
Transporter T6 Combi 2017: IMG_3575
elevator.kuvat.fi
Thanks Kind of BlueA very practical and useful 4Motion. For work, rest and play. Plenty of lights for the long dark nights, are they all https://www.lazerlamps.com ? I imagine that lot would turn night into day. Even seeing behind for reversing. What do you use the work lights mounted close to the door mirrors for?
I am considering Lazer lamps myself. They have quite a variety. I quite like the responsive dipping light bar, perhaps mounting within the radiator grill. Cutting out a section of grill but replacing it to hide the light bar for when I visit a town or city to prevent theft. Good spread is more important than range I feel but they also need to comply with lighting regulations. Lots of very narrow twisting country roads in Wales and off road driving.
The manufacturers original fit LED headlamps are not so bad in the dry but as we get more of our fair share of rain here, they become poor with not enough spread or illumination for tight multiple bends. Reversing on dark wet nights is a problem. The reversing camera gets splatter from mud and road debris. Even after cleaning it it get smeared over quite quickly. A reverse camera mounted inside the rear window would be better, then the rear wipers would take care of splatter.
I quite like the idea of a roof rack similar to yours perhaps, lamps mounted rear wards up there might be an answer. Do you know the weight of your roof rack carrier when empty? My vehicle 2019 4Motion Caravelle with rear differential lock 255/55R18 BFG AT KO2. I think that yours, are 245/65R17 BFG KO2 AT ? Do you have the rear Differential lock? I find it very useful. I live off road at a remote hill farm/smallholding, no stock. I usually engaged the rear diff just to ensure it did not end up stiff and unusable due to lack of use.. I always felt that the vehicle felt far tighter off road, with it engaged and wondered why, as some time when the going was not that very difficult and the 4Motion might not be then operating normally and only engage with front axle slip. It just felt very positive and in places that I expected a front wheel should slip or spin slightly it would not and instead traction remain excellent. I now have learnt on here, that indeed, engaging the diff-lock, pre engages the 4Motion, so explaining the better traction at all times and my experiences.
I will need to lift the suspension, would really like air but very expensive in comparison to a full height spring and damper lift. Self levelling when parked up and camping is very much a dream. Also I would only need lift when off road and could even drop height to limbo under height restriction gates that are becoming all too common these days.
Many years ago I used a Finish 4x4 forum. I had ex military vehicles over a period of time LR101FC with crew cab, Volvo TGB 6x6 with crew cab portal axles and diff locks in all axles. UNIMOG U900 crew cab with smaller rear tub and of course portals and diff locks. I could see that Finland has a very serious off road following and plenty of countryside. I unfortunately never visited.
Any way, I like your vehicle and your adaptations and i also see that you have a willing crew! Happy motoring!![]()
Thank you for the reply and the lamp reference. Your written English is just fine. I rely on spell checker quite a lot and if I publish without reading first it can come out rather strange with often unintended words and meaning. I come from here and so have no excuse. You have at lest two languages and can most probably get on with others also.Thanks Kind of Blue
In First, have to say, I read English better than I write itBut I will learn…
Lazer lamps are too expensive in Finland, so front lamps are W-light Booster 9 lamps and on the roof Purelux Black X-Slim S1000. Side lamps and rear lamps are Purelux Terrain Black Slim Flood 30W. Those hood lights are Bullpro Spectrum Ellipse 54W. I drive a lot at night and it's very dark in the winter time. I think I don't have too many lights, maybe they will increase in winter. Have to check BlackFriday sales.
I have mutch more pics here:
Ruotsin tulijaisia Kamuxin kautta meille. 5 paikkainen Transporter KOMBI 150kW TDIAL7 CXEB. Auto ääni ja lämpöeristetty omasta toimesta. Käytetty Vevor äänieristeitä ja raskasmattoja sekä 13mm armaflex eristettä. Alkuperäiset takaosan verhoilut purettu ja asennettu autoon valmistetut...elevator.kuvat.fi
I don't have a diff lock thats why those tires. Okay, those tires are pretty tooDiff lock is not a very common equipment here. I didn't choose the equipment for the car myself, so it is what it is. And you are right, those ar BFG AT Ko2 245/65 17. Sometimes I drive off-road, but I pull more of a boat trailer. This car is a compromise with those things. I have looked into whether a difflock could be built into this car, but the matter is still in progress. Maybe I’ll lift car too with some lift kit. At that time, if I go to very harsh places, I lower the tire pressure below 1.5bar and drive with extra care. Earliee I got a rear wheel drive+ manual MB Sprinter and learned to drive it quite well without getting stuck. Now driving is easy with 4motion with DSG.
I write more with better time…
Van looking nice DaveTMP lift kit (+35mm)
17” Fuel Zephyr
Falken Wildpeak
THQ LED lights
Lazer Lamps
View attachment 280916View attachment 280917View attachment 280918View attachment 280919View attachment 280920View attachment 280921
No idea, not even thought about that!!?Van looking nice Dave
Can you level the new THQ headlights, I’ve been looking at those but not sure how they would be with a lifted van on larger tyres, would they dazzle on coming drivers
Tyres as long as they where all of equal size would make very little difference to the beam projection large or small. Obvious when lifting the same should be true if all 4 corners where lifted by the same amount. the problem generally arises if someone started fussing about the rear low or high for the sake of appearance then that would alter the beam projection if it was adjusted. If a vehicle was raised equally the beam drop angle should be the same that is projecting at the same angle down but might cut a slightly higher mark on the garage door at the same distance but unless it was razed by feet rather than inches it aught not to be a problem and should not dazzle oncoming vehicles.Van looking nice Dave
I’m hoping they will be ok, my van is up by about 30 mm, I’ve got the sh@t 6.1 headlights and I do get flashed every now and then, and put it down to the lift, I need to swap them for some that actually work to light the road when on dipped beamTyres as long as they where all of equal size would make very little difference to the beam projection large or small. Obvious when lifting the same should be true if all 4 corners where lifted by the same amount. the problem generally arises if someone started fussing about the rear low or high for the sake of appearance then that would alter the beam projection if it was adjusted. If a vehicle was raised equally the beam drop angle should be the same that is projecting at the same angle down but might cut a slightly higher mark on the garage door at the same distance but unless it was razed by feet rather than inches it aught not to be a problem and should not dazzle oncoming vehicles.
There has been simple instructions on paper and on line for decades of how to DIY correct headlamp beam projection against a wall or garage door in such a way to satisfy MOT and not dazzle. Most garage have beam correction evaluation devices anyway and that is a very fast service. The only thing with the latter is, most garage hands doing it are far too brief and give far too little attention to the task and are generally only concerned with pass or fail and will often over correct and not achieve the best finite result.
In the short term just drop in at local Halford branch and buy their best halogen bulbs have them fit them cost little and they do it every day. I bought some dipped bulbs for daughters Dacia Duster a bit tight but the very young lady possibly still at school (I must be very old, most police men look like pimply school boy's to me) knew exactly what to do and had old out, new in, at a blink of the eye. Go home look up how to adjust headlamps, draw the marks and crosses on a garage door or wall set them up by adjusting the screws job done. Phillips and Osram are the best but unless their are alternative motor-factors in your nearest town Halford bulbs are OK or just buy on line but will need to fit your self.I’m hoping they will be ok, my van is up by about 30 mm, I’ve got the sh@t 6.1 headlights and I do get flashed every now and then, and put it down to the lift, I need to swap them for some that actually work to light the road when on dipped beam
