If the roof had moved backwards the cam would engage MORE with the bars so that's not it.Mine opens but only on the right side. Not user error, totally fastened down so the roof is pulled tight. It happened on motorway. Luckily I heard it so pulled over immediately. I have now have to put a ratchet strap around the handle of the poptop to the handle at drivers side where you get in the cab. Coming back from Scotland at weekend it was terrible. Perhaps every 4 mins it would pop off the catch. I’ve really lost confidence in it. Definitely not user error., I pull the roof down from outside and feel the cam pulling it tight to roof. It’s also strange that is didn’t happen from the beginning when first fitted.It’s like the roof has moved back? I’m now trying to get a thicker bar cut and put inplace on the roof. No way would I now drive without my botch of the ratchet straps in place. Fuming after near 4K for the lwb version.
This is an interesting photo, when did you get your roof fitted ? Mine is in just now because the front cams were squeaking, indicating some sort of movement. The cams sent to replace the ones I have are these ones pictured. Notice there are normally 3 screws holding the cam lock to the roof, but in this design the cam is tightened in a manner that basically sandwiches it against the roof with wavy washer underneath. So even in this thread 3 different cam designs. The skyline videos on fitting still show the drilling of 3 holes and fitting of cams that way.One more photo
The roof was fitted 12 months ago by converter but one of the cams worked lose so I pop it into skyline in Somerset and they fitted the new ones in October been good ever sinceThis is an interesting photo, when did you get your roof fitted ? Mine is in just now because the front cams were squeaking, indicating some sort of movement. The cams sent to replace the ones I have are these ones pictured. Notice there are normally 3 screws holding the cam lock to the roof, but in this design the cam is tightened in a manner that basically sandwiches it against the roof with wavy washer underneath. So even in this thread 3 different cam designs. The skyline videos on fitting still show the drilling of 3 holes and fitting of cams that way.
My converter who is fitting the new cams are concerned about the cam overlap with the bar on the pop top. So are fitting a wider bar to ensure better overlap. Only thing is they only have mild steel instead of stainless so I'll monitor it for any bending!
Ah that makes sense. Mine was also fitted 12 months ago but now in for the new cam locks.The roof was fitted 12 months ago by converter but one of the cams worked lose so I pop it into skyline in Somerset and they fitted the new ones in October been good ever since
So they have pulled the roof back on the hinges to get more lever over the flat roof brackets which suggests the measurements are wrong, in way of front roof mount to back, if you watch the mechanic fitting the aurora on you tube, he marks it out with a tape measure then, before marking his cut lines, he brings it back 10 mmI would have been doing 50mph+ when it opened. The installers had to reposition it slightly on the roof of the van as it had moved slightly apparently. There was no damage to the pop top or the van. What is different since that incident after adjusting the roof is that the pop top sits a little further back than it did after it was first installed. The pop top originally brushed the rubber deflector as it closed when it was being shown to me on collection. There is now a gap.
Oh sh*t - Oh sh*t.A Skyline heading north on M6 this morning was lifting on the drivers side. Not sure what the international sign language for “your poptop’s not shut mate” is.
Reach out to Skyline. Customer service is pretty good.Does anyone know how to tighten the catches ? One side of mine has some slight movement and causes a creak as the pop top moves up and down ever so slightly, i can feel it if I put my finger in the key hole when driving. I'm assuming it'll be key on the inside and screw driver /socket on the outside?
