(Solved) Van won't start after work on the wiring under the passenger seat.
Maybe this has been mentioned and I have missed it.
Can you use one jump cable, clamp one end on the engine block(or any exposed engine solid piece of metal) and the other end on battery negative terminal?
And then attempt to crank your engine.
Just tried that and no joy.
When the ignition is switched ON but isn't started I hear a little buzz when I'm near the engine compartment, like a taser sound, is that normal or could this be the fault?
Well the new battery is coming on Tuesday, couldn't justify paying the high prices locally £150 extra ECP wanted for the same battery I ordered online!
I have checked the starter relays out of the van with a multimeter and they were working as they should with a voltage applied..
I also tried the van with a battery my neighbour has that seemed to have decent charge in it but still had the same result.
Reactions: mmi
Did a few more tests and I have power at the following fuses: SC23 Starter relays, SC38 Ignition supply to key, SC39 Ignition starter.
I also have power at SC56 BCU starter feed when the key is turned.
I am going to see if I can work out how to test for power coming from the starter relays tomorrow I think.
Any info that could help me out with this will be great, thanks all.
Reactions: mmi
I have ordered a new battery as this one seems to be draining anyway, I charged it overnight to get the following readings from when the key is turned from ON to START.
Address 01: Engine (04L 906 056 KG)
14:03:38
IDE00018 Voltage terminal 15 11.986 V
IDE00019 Voltage terminal 30 11.907 V
IDE00020 Terminal 15 status On
IDE00412 Starter control: terminal 50 not active
IDE00413 Starter control: Interlock- or P/N-signal active
IDE00416-MAS07386 Starter control: terminal 50 feedback-Terminal 50 on CAN not active
IDE00416-MAS09390 Starter control: terminal 50 feedback-Terminal 50 CAN valid active
IDE00416-MAS09391 Starter control: terminal 50 feedback-Terminal 50 via cable not active
IDE00416-MAS09392 Starter control: terminal 50 feedback-Starter relay not active
IDE00416-MAS09394 Starter control: terminal 50 feedback-Starter operation read back wire T50Ret not active
IDE00416 Starter control: terminal 50 feedback 8
These are ok for IGNition ON, but not for START.
To initiate starting sequence we should see first - IDE00412 Starter control: terminal 50 ACTIVE
Well, a couple of easy checks
Terminal 50 and Terminal X (at START) status seen on BCM side
VCDS > Select Control Module > 09-Cent. Elect. > Adv.Meas.Values >
Status Terminal 50 (should turn ON)​
Status Terminal X (should momentarily go OFF)​
Also status of brake switch (though should be seen on dash, too)
VCDS > Select Control Module > 01-Engine > Adv.Meas.Values >
IDE07904-ENG118117 Brake test switch status-actuated__activated​
I tested the brake in vcds yesterday as I thought it would be needed.
I will check the others today, thank you. :)
Status Terminal 50 Stays OFF in both positions.
Status Terminal X Stays ON in both positions.
Tested the brake again and it is operating as it should.
Would the above suggest that the relays aren't being triggered for some reason?
VCDS scan:
Sunday,30,July,2023,12:35:25:49617
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 23.3.1.0 (x64) HEX-V2 CB: 0.4631.4
Data version: 20230421 DS346.2
www.Ross-Tech.com
VIN: WV1ZZZ7HZHH145893 License Plate:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 02 03 04 08 09 15 17 19 25 5F 61 69 0B
VIN: WV1ZZZ7HZHH145893 Mileage: 211410km-131364miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
61-Battery Regul. -- Status: OK 0000
69-Trailer -- Status: OK 0000
Address 01: Engine (2D2D2-CXHA) Labels:. 04L-907-309-V2.clb
Part No SW: 04L 906 056 KG HW: 04L 907 445
Component: R4 2.0l TDI H02 3771
Revision: 23002001
Coding: 00254014431501090000
Shop #: WSC 50234 002 1048576
ASAM Dataset: EV_ECM20TDI03004L906056KG 004004
ROD: EV_ECM20TDI03004L906056KE_004.rod
VCID: 7CA1E61C26677AFA533-8028
VINID: 9E606AAAA1D8A986011052090C6B331798
No fault code found.
Readiness: N/A
Address 02: Auto Trans (J743) Labels:. 0BH-927-711.clb
Part No SW: 0BT 300 046 J HW: 0BH 927 711 G
Component: DSG DQ500-7F H11 5301
Revision: 00H11V01 CVN: A5BFDF55
Coding: 0014
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_TCMDQ500021 001001
ROD: EV_TCMDQ500021_001_VW36.rod
VCID: 3D272B187DFDB3F224D-8068
Address 03: ABS Brakes (J104) Labels: 7E0-907-37x-MK100ESC.clb
Part No SW: 7E0 907 379 P HW: 7E0 907 379 M
Component: ESC H06 0133
Revision: 00000000 Serial number: 40727000000388
Coding: 517E4098256684838A7D027FA48521E6790000
Shop #: WSC 02739 790 50316
ASAM Dataset: EV_Brake1ESCCONTIVN75XGP2 011001
ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
VCID: 3FDB511077F1A1E2361-806A
Address 04: Steering Angle (G085) Labels:* 6R0-959-654.clb
Part No SW: 6R0 959 654 HW: 6R0 959 654
Component: LENKW.SENSOR H07 0070
Serial number: 03031713471417
Coding: 01
ASAM Dataset: EV_LWSKLOVW25X 005001
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA5EC14307B68EA7D7-802A
Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb
Part No SW: 7E0 907 047 AK HW: 7E0 907 047 AK
Component: Climatic-T5 H22 0708
Revision: 00001002
Coding: 0000000003
Shop #: WSC 02737 790 50316
ASAM Dataset: EV_ClimaticT5 A01003
ROD: EV_ClimaT5Basis.rod
VCID: 73B3CD200B393582029-8026
Address 09: Cent. Elect. (J519) Labels:. 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 B HW: 7E0 937 090
Component: BCM PQ25 Max4 H81 0744
Revision: B9081001 Serial number: 0982 069170760
Coding: A0AC393A0A613411802849742C2B8C548F10710F60464D60320400230800
Shop #: WSC 02737 022 2044595
VCID: 2A0D10449CF3344A71F-807E
Subsystem 1 - Part No SW: 7E0 959 801 Q HW: 7E0 959 801 Q Labels: 7E0-959-80X-V2.CLB
Component: J386__TSG_FT 003 0653
Serial number: KU0KU001031770604278
Coding: 1400B1
Subsystem 2 - Part No SW: 7E0 959 802 Q HW: 7E0 959 802 Q Labels: 7E0-959-80X-V2.CLB
Component: J387__TSG_BT 003 0653
Serial number: KU0KU001031770604849
Coding: 0400A1
Subsystem 3 - Part No: 1K0 951 605 F
Component: LIN BACKUP HO H01 0008
Coding: 000000
Subsystem 4 - Part No SW: 2H0 959 442 HW: 2H0 959 442
Component: E221__MFL-DC1 H02 0103
Serial number: 46170000637210127095
Coding: A4FFFF
2 Faults Found:
03303 - Response Closing Status of Rear Left Door
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 93
Mileage: 211417 km
Time Indication: 0
Date: 2017.12.20
Time: 02:52:51
03444 - Ignition Starter Switch
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 93
Mileage: 211417 km
Time Indication: 0
Date: 2017.12.20
Time: 04:32:21
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 7E0 959 655 G HW: 7E0 959 655 G
Component: VW10Airbag01T H08 0018
Revision: -------- Serial number: 003V30047AFU Dataset Number: 7E0003V____ 0881
Coding: 000000000000000000000000000000003154
Shop #: WSC 02734 790 50316
ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 3A2D20046CD384CA01F-806E
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 7E0 920 970 S HW: 7E0 920 970 S
Component: KOMBI H03 1104
Serial number: 00000000000000
Coding: 440B010300
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733
ROD: EV_Kombi_UDS_VDD_RM09_005_VW25.rod
Address 19: CAN Gateway (J533) Labels:. 7E0-909-901.clb
Part No SW: 7E0 909 901 HW: 7E0 937 090
Component: GW-K-CAN TP20 H81 0744
Revision: B9081001
Coding: 042305
VCID: 6889AA4C427FC65AA7B-803C
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H03 1104
Serial number:
Coding: 000000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
VCID: 6A8DD0445CF3F44AB1F-803E
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-ENT2.clb
Part No SW: 1K8 035 150 L HW: 1K8 035 150 L
Component: MU-E-D-ER 055 7085
Serial number: 21021700011435 Dataset Number: V03935253YT 0001
Coding: 065700003C00000041111101008000001F0000C60000010001
ASAM Dataset: EV_MUEnt4CGen2LGE 001032
ROD: EV_MUEnt4CGen2LGE_VW32.rod
VCID: 2E051C54A09B586AAD7-807A
3 Faults Found:
0001 - Antenna 1 for Radio
B1119 13 [009] - Open Circuit
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 53
Mileage: 211417 km
Date: 2023.07.30
Time: 01:59:06
Voltage terminal 30: 12.2 V
1564 - Microphone 1
B129B 13 [009] - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 53
Mileage: 211417 km
Date: 2023.07.30
Time: 01:59:06
0011 - Digital Radio Antenna
B1103 13 [009] - Open Circuit
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 53
Mileage: 211417 km
Date: 2023.07.30
Time: 01:59:06
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 7E0 907 534 HW: 7E0 937 090
Component: Batt.regelung H81 0744
Coding: 330B1A73
Shop #: WSC 80093 222 69422
Subsystem 1 - Part No SW: 7E0 915 181 K HW: 7E0 915 181 K
Component: J367-BDMConti H03 1050
Serial number: 758857000017030303E0
Address 69: Trailer (J345) Labels:. 1K0-907-383-V2.clb
Part No SW: 1K0 907 383 H HW: 1K0 907 383 G
Component: Anhaenger H12 0130
Revision: 3B001001 Serial number: 00000433558251
Coding: 410D000103000000
VCID: 323D0824B4237C8AC9F-8066
End----(Elapsed Time: 01:22, VBatt start/end: 11.8V/11.9V. VIgn 11.9V)-----
I have found the problem, I thought about the wiring loom under the seat, wondering if I had sliced a wire by accident or something under the rubber carpet, I had, and had wrapped it back up in tape, joined it back together and it started right up!
I'm going to solder and heat shrink it now.
Thanks to everyone for all the help, I think I still would have needed a new battery so will still fit that when it gets here.
Congrats - by any chance made a note what colour the wire is, any connector in the vicinity?
I guess somehow related.
PS. Thanks for sharing the challenge.
