Here is all the information from a VCDS scan:
Code:
Friday,28,July,2023,15:04:54:49617
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 23.3.1.0 (x64) HEX-V2 CB: 0.4631.4
Data version: 20230421 DS346.2
www.Ross-Tech.com
VIN: WV1ZZZ7HZHH145893 License Plate:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 02 03 04 08 09 15 17 19 25 5F 61 69 0B
VIN: WV1ZZZ7HZHH145893 Mileage: 211410km-131364miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
61-Battery Regul. -- Status: OK 0000
69-Trailer -- Status: Malfunction 0010
Address 01: Engine (2D2D2-CXHA) Labels:. 04L-907-309-V2.clb
Part No SW: 04L 906 056 KG HW: 04L 907 445
Component: R4 2.0l TDI H02 3771
Revision: 23002001
Coding: 00254014431501090000
Shop #: WSC 50234 002 1048576
ASAM Dataset: EV_ECM20TDI03004L906056KG 004004
ROD: EV_ECM20TDI03004L906056KE_004.rod
VCID: 7CA1E61C26677AFA533-8028
VINID: 9E606AAAA1D8A986011052090C6B331798
6 Faults Found:
31103 - SCR NOx Catalyst Bank 1
P20EE 00 [096] - Efficiency too Low
Intermittent - Not Confirmed - Tested Since Memory Clear
16230 - Control Module for Instrument Cluster
U1019 00 [032] - Missing Signal for Oil Level/Temperature
[Instrument cluster control moduleMissing signal oil level/temperature]
27202 - Sensor Reference Voltage A
P0641 00 [032] - Open Circuit
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 3
Mileage: 211265 km
Date: 2069.01.12
Time: 13:03:01
Engine RPM: 47.50 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 20 °C
Intake air temperature: 16 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 4.296 V
Unlearning counter according OBD: 34
Engine status: Engine start
Engine running time-Pressure BIN10 bar: 0 s
Control Module temperature: 25.2 °C
ESM_Battery_voltage-Voltage: 4.32 V
Low battery mode active-Bool type: No
ESM_Vext_raw-ESM_sensor_voltage: 3.2891 V
Starter control: terminal 50 feedback-Terminal 50 on CAN: active
Starter control: terminal 50 feedback-Terminal 50 CAN valid: active
Starter control: terminal 50 feedback-Terminal 50 via cable: active
Starter control: terminal 50 feedback-Starter relay: active
Starter control: terminal 50 feedback-Starter operation read back wire T50Ret: active
Starter control: terminal 50 feedback: 62
Starter control: shut-off conditions 1-Immobilizer: not active
Starter control: shut-off conditions 1-Starter shift malfunction: not active
Starter control: shut-off conditions 1-Speed: not active
Starter control: shut-off conditions 1-Drivetrain: not active
Starter control: shut-off conditions 1-RPM aborted starts: not active
Starter control: shut-off conditions 1-Engag. duration: not active
Starter control: shut-off conditions 1-Engag. duration aborted starts: not active
Starter control: shut-off conditions 1-Engag. duration panic start: not active
Starter control: shut-off conditions 1-new errors: not active
Starter control: shut-off conditions 1-manual start/error: not active
Starter control: shut-off conditions 1-ignition: not active
Starter control: shut-off conditions 1-Clutch error/terminal 50 malfunction: not active
Starter control: shut-off conditions 1-Direct start function: not active
Starter control: shut-off conditions 1-Engag. duration defrost.: not active
Starter control: shut-off conditions 1: 0
27200 - Sensor Reference Voltage B
P0651 00 [032] - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Mileage: 211265 km
Date: 2069.01.12
Time: 13:03:01
27198 - Sensor Reference Voltage C
P0697 00 [032] - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Mileage: 211265 km
Date: 2069.01.12
Time: 13:03:01
Engine RPM: 95.25 /min
Voltage terminal 30: 5.515 V
ESM_Battery_voltage-Voltage: 5.22 V
27196 - Sensor Reference Voltage "D"
P06A3 00 [032] - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Mileage: 211265 km
Date: 2069.01.12
Time: 13:03:01
Readiness: N/A
Address 02: Auto Trans (J743) Labels:. 0BH-927-711.clb
Part No SW: 0BT 300 046 J HW: 0BH 927 711 G
Component: DSG DQ500-7F H11 5301
Revision: 00H11V01 CVN: A5BFDF55
Coding: 0014
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_TCMDQ500021 001001
ROD: EV_TCMDQ500021_001_VW36.rod
VCID: 3D272B187DFDB3F224D-8068
No fault code found.
Address 03: ABS Brakes (J104) Labels: 7E0-907-37x-MK100ESC.clb
Part No SW: 7E0 907 379 P HW: 7E0 907 379 M
Component: ESC H06 0133
Revision: 00000000 Serial number: 40727000000388
Coding: 517E4098256684838A7D027FA48521E6790000
Shop #: WSC 02739 790 50316
ASAM Dataset: EV_Brake1ESCCONTIVN75XGP2 011001
ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
VCID: 3FDB511077F1A1E2361-806A
Address 04: Steering Angle (G085) Labels:* 6R0-959-654.clb
Part No SW: 6R0 959 654 HW: 6R0 959 654
Component: LENKW.SENSOR H07 0070
Serial number: 03031713471417
Coding: 01
ASAM Dataset: EV_LWSKLOVW25X 005001
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA5EC14307B68EA7D7-802A
Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb
Part No SW: 7E0 907 047 AK HW: 7E0 907 047 AK
Component: Climatic-T5 H22 0708
Revision: 00001002
Coding: 0000000003
Shop #: WSC 02737 790 50316
ASAM Dataset: EV_ClimaticT5 A01003
ROD: EV_ClimaT5Basis.rod
VCID: 73B3CD200B393582029-8026
Address 09: Cent. Elect. (J519) Labels:. 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 B HW: 7E0 937 090
Component: BCM PQ25 Max4 H81 0744
Revision: B9081001 Serial number: 0982 069170760
Coding: A0AC393A0A613411802849742C2B8C548F10710F60464D60320400230800
Shop #: WSC 02737 022 2044595
VCID: 2A0D10449CF3344A71F-807E
Subsystem 1 - Part No SW: 7E0 959 801 Q HW: 7E0 959 801 Q Labels: 7E0-959-80X-V2.CLB
Component: J386__TSG_FT 003 0653
Serial number: KU0KU001031770604278
Coding: 1400B1
Subsystem 2 - Part No SW: 7E0 959 802 Q HW: 7E0 959 802 Q Labels: 7E0-959-80X-V2.CLB
Component: J387__TSG_BT 003 0653
Serial number: KU0KU001031770604849
Coding: 0400A1
Subsystem 3 - Part No: 1K0 951 605 F
Component: LIN BACKUP HO H01 0008
Coding: 000000
Subsystem 4 - Part No SW: 2H0 959 442 HW: 2H0 959 442
Component: E221__MFL-DC1 H02 0103
Serial number: 46170000637210127095
Coding: A4FFFF
4 Faults Found:
01758 - Bulbs for Brake Lamps
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 93
Time Indication: 0
00329 - Control Circuit for Unlocking Rear Lid
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 87
Mileage: 211265 km
Time Indication: 0
Date: 2017.11.30
Time: 17:42:52
03301 - Response Closing Status of Drivers Door
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 93
Mileage: 211417 km
Time Indication: 0
Date: 2017.12.18
Time: 00:08:52
03303 - Response Closing Status of Rear Left Door
Freeze Frame:
Fault Priority: 2
Fault Frequency: 49
Reset counter: 93
Mileage: 209997 km
Time Indication: 0
Date: 2017.07.19
Time: 11:33:12
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 7E0 959 655 G HW: 7E0 959 655 G
Component: VW10Airbag01T H08 0018
Revision: -------- Serial number: 003V30047AFU Dataset Number: 7E0003V____ 0881
Coding: 000000000000000000000000000000003154
Shop #: WSC 02734 790 50316
ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 3A2D20046CD384CA01F-806E
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 7E0 920 970 S HW: 7E0 920 970 S
Component: KOMBI H03 1104
Serial number: 00000000000000
Coding: 440B010300
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733
ROD: EV_Kombi_UDS_VDD_RM09_005_VW25.rod
Address 19: CAN Gateway (J533) Labels:. 7E0-909-901.clb
Part No SW: 7E0 909 901 HW: 7E0 937 090
Component: GW-K-CAN TP20 H81 0744
Revision: B9081001
Coding: 042305
VCID: 6889AA4C427FC65AA7B-803C
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H03 1104
Serial number:
Coding: 000000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
VCID: 6A8DD0445CF3F44AB1F-803E
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-ENT2.clb
Part No SW: 1K8 035 150 L HW: 1K8 035 150 L
Component: MU-E-D-ER 055 7085
Serial number: 21021700011435 Dataset Number: V03935253YT 0001
Coding: 065700003C00000041111101008000001F0000C60000010001
ASAM Dataset: EV_MUEnt4CGen2LGE 001032
ROD: EV_MUEnt4CGen2LGE_VW32.rod
VCID: 2E051C54A09B586AAD7-807A
2 Faults Found:
1564 - Microphone 1
B129B 13 [009] - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 53
Mileage: 211417 km
Date: 2023.07.28
Time: 20:50:09
Voltage terminal 30: 12.1 V
0011 - Digital Radio Antenna
B1103 13 [009] - Open Circuit
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 23
Mileage: 209997 km
Date: 2023.02.26
Time: 11:29:12
Voltage terminal 30: 14.0 V
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 7E0 907 534 HW: 7E0 937 090
Component: Batt.regelung H81 0744
Coding: 330B1A73
Shop #: WSC 80093 222 69422
Subsystem 1 - Part No SW: 7E0 915 181 K HW: 7E0 915 181 K
Component: J367-BDMConti H03 1050
Serial number: 758857000017030303E0
Address 69: Trailer (J345) Labels:. 1K0-907-383-V2.clb
Part No SW: 1K0 907 383 H HW: 1K0 907 383 G
Component: Anhaenger H12 0130
Revision: 3B001001 Serial number: 00000433558251
Coding: 410D000103000000
VCID: 323D0824B4237C8AC9F-8066
2 Faults Found:
02564 - Trailer; Left Tail Lamps (M60)
010 - Open or Short to Plus - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 71
Mileage: 210612 km
Time Indication: 0
Date: 2017.07.22
Time: 10:29:47
00532 - Supply Voltage B+
011 - Open Circuit - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 87
Mileage: 211265 km
Time Indication: 0
Date: 2017.11.29
Time: 17:28:33
End----(Elapsed Time: 01:29, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
