I would say the natural/normal(=not extreme) camber of the roads is not a factor. Up here the LHD T5/T6s do not pull to the right, and not to the left on left lane.I'm assuming the natural camber of the roads in the UK has been ruled out? Or are there lots of threads in europe " my T6 pulls to the right!"
I've tried swapping wheels and it has helped. But it's still there . I agree camber is not the major factor . When I drove to Scotland last week towing a caravan it was worse. It was almost like I was holding the steering wheel right to keep a straight line , but on a very very slight left hand kink the van felt neutral and at ease .I would say the natural/normal(=not extreme) camber of the roads is not a factor. Up here the LHD T5/T6s do not pull to the right, and not to the left on left lane.
Anyone tried swapping front left and right wheels to see if that makes difference? Or front to rear, or even different set of wheels. Broken/loose tyre belts are rare but not exceptional, just had one on my car a few months ago - which made it pull right. Replacement of the tyre cured the pull.
Update ,
Took van to addison tyres in Tipton. Good bunch of lads . They have checked tow and camber and rear tow is out and front camber out. They have now sorted the tow and the steering wheel is now straight. They did say the van may still pull slightly as they can't adjust the camber on the t6 unless you fit a special bolt or the pro bushes . So the out come it drives better , wheel straight but still a little pull. Custom vans are a waste of time , selling modded vans and saying VW will honour warranty. VW dealer say NO they won't . Interesting
Also a note @Shredder comment on codes for different vans on the hunter system is bang on the money . So well done for that info
Try Addison tyres in Tipton. Noticed your cov so it's not that far, plus they do all the alignment for VW in bilston.. just make sure you put the steering wheel where you want it .ok so this is tempting me to go to another alignment place from the one I've been to twice who said mines fine apart from a bit of camber due to it being lowered.
Is there a specific setting on the hunters machine that the garage need to select?
I've ordered h&r sway bars so I'll update you when I fit them on my finding .
View attachment 25977 You need your suspension code off vehicle
Under drivers side dash
Guess its to do with weight etc and differant suspension on dofferant vans..
Never going to get a petfect set up , due to b14s /tyres/ lowering height etc
But read on here that using base settings on factory sus will give a half decent reading etc
Has anyone fitted rear camber adjusting bushes?
