here a small bit of additional data . . . .
as you may know the van was sent off to the repair center after having the side caved in, anyway all good now. but look at the Ctek battery monitor readout for both batteries over that duration.
the van was layed up for around 5 weeks with the odd start here and now. Both batteries show very poor SOC/SOH atm.
Over the xmas break i did connect the Noco GB1500 charger to each intern until it registered 100% . . . . but they seem to be dropping back down fairly quickly.
this shot shows the current SOH/SOC as of today.
This shot shows the gradual decline in the main battery over November into December, The first large spike was them boost pack starting the van and a drive home + a few days work. The large spike near the ens is me with the charger.
A similar story here with the AUX battery, gradual decline, few short drives.. then a mains charge over xmas about 4 days ago. This Aux battery has the Redarc DC-DC charger connected to it using the ignition feed (BCM relay feed) as a trigger/turn on.
this is the 15amp Noco GB1500 smart charger
The only thing connected to these battery's apart from the OEM setup is a 12v USB charger/power supply for USB kit.
Ill run the van properly/daily soon and expect both batteries to rise upto 80%/100% SOC/SOH
Moving forwards i might look a getting a small "50W small solar panel" to sit on the dash via a PWM/MPPT controller plugged into the dash 12v socket as a temp measure to help keep the battery topped up while parked up for extended periods 1/2/3 weeks.
was also considering the twin battery onboard EHU charger that
@mmi mentioned as an option.
her are some of the BM2 datalog readouts . . .
this one shows the AUX batt flat at the repairers.
this one shows the days after getting the van back and a day out and about. (you wont see the 15v regen highs as this battery is now connected to the Redarc DC-DC which filters out/isolates the battery from the starter/alternator.
this one shows the GB1500 charge process over the 7hours it was connected
this one shows today, after sitting for another 5days after being charged.... then a short trip at 10am.
