So if I'm reading this right....if I purchased 20x9 with 275/40/20 tyres it would rub on tge front?
Yeah it sounds that way if you are lowered on B14's.
A 275 40 19 is as perfect a size in 19 as 275 35 is in 20. You'll just need a heat gun for the inner arch. Is it probably touching on the outer lip on a pot hole?
Ok so I've been doing a little research this morning and have come accross a 265/40/20 104 tyre. It's still not ideal, and is oversize, but is nearer to where we need to be. This, with a ET40 8.5/9x20 wheel should give us the little extra clearance we need - 10 mm or so. I'm in the process of ordering tyres and wheels and will report back.
Yes, I'm running 20" ATS Temperament wheels (load rated for a T32) with B14's down pretty low. I have 275/40/20 get a lot of rubbing it!!@gmaster what is your set up? Noticed that you are running 20's? Are you also running B14's?
@BognorMotors What wheels are you running in your avatar? are these T32 load rated?
Yes, but all dependant on tyres and offset, so not sure how much . Should know more this coming week, once we test fit the 265/40/20. Still trying to find a decent black 8.5/9x20 with on offset of 40. Will keep you all in the loop
Hello. They are a lovely wheel and perfect for the T30 weight rating wise. They are an 8.5x20 ET40. We ran a 275/35 on them.
Thanks for this , with a 30mm lower I shouldn't get any rubbing issues I would hope ? Et 40 should give it a nice flush fit , do you have any more pictures of the van with them and where do you recommend I purchase from ? Sorry for all the questions but do appreciate your input
