If you cant get the battery out, perhaps you shouldnt be doing a full install JokeI am in the process if planning a leisure battery install and dc-dc charger.
However firstly I cant work out how to remove the battery to get access to the bulkhead grommets. Secondly is it possible to take power from the fusebox that is on top of the battery. I seem to have some of these unused.
i probably could, but was asking for the correct way firstIf you cant get the battery out, perhaps you shouldnt be doing a full install Joke
when you find out, let me knowi probably could, but was asking for the correct way first
yes perfect for that.Secondly is it possible to take power from the fusebox that is on top of the battery? I seem to have some of these unused.
It looks like WV have just done on the T6.1 what we have allready done on the T6 . . . . . . . . added an extra FuseBox next to the battery.
for the big cables as the battery post gets full up . .
VW solution . . . 2021
our solution . . . . 2018
View attachment 105414View attachment 105415
i must say i do like that solution ( i like mine too) . . . but very neat from VW. - wonder if you can get it as a retro fit for T6?
Same thing !!!!
Its definitely not that. The top part seems to be hinged at the front, I can release a clip at the back right but then Im stuck :/come on . . its a fuse box, so a serviceable item.
get your trim tools out.
pop the clip at the front to get it off the battery.
then get the trim tools on it . . . .
post pics of the inside . . . . .
спасибо @skoroxod
это ваш фургон, ваши фотографии?
что это за синяя штука на клеммах аккумулятора?
можете ли вы получить несколько фотографий крупным планом предохранителей и шины в блоке предохранителей SJ?
Вот обещанное фото. Сфотографировал обложку этого блока. Здесь все понятно, как прикреплено. Я не нашел синего баллончика с распылителем. У нас такой спрей продается в каждом магазине и везде разный. Есть много разновидностей таких спреев.@skoroxod
thank you. have you got a link for that blue Grease?
look forward to the new pic tomorrow.
Normfest Poltec - Battery-Terminal Protection Spray 300mlProduct Code: NOR2897332300
