T6.1 BiTurbo dead at 143K :(
nonlineartom
I purchased a T6.1 T32 199PS just last week, 20 plate, with 142k miles on the clock, I knew it was high risk with the mileage but there was a full service history for oil change every 10k on the dot, new belt and pump, all the stuff I thought I had to look out for. It was just about in budget and I needed something Euro6.
The first 5 miles were lovely, then it went into a limp mode just as I was heading to Scotland for a job, no real opportunity to turn back. I did another 250 miles, then got engine warning light, DPF blocked, figured this was because it wasn't regenerating, got the DPF flushed out in Glasgow before attempting the return leg to Yorkshire. It had no power, but there was no smoke, no drama or weird sounds from the engine, it was that or a ridiculously expensive trailer ride home.
Got it to a VW specialist in Leeds the next morning, and there's filings and oil in one of the turbos, Garage have quoted 5K to supply and fit a new Bi-Turbo, part 03N145704L, said they won't know if anything else is damaged until they get it apart.
Long time lurker on this forum, read lots of horror stories about this engine, my old transporter was a 102 Bluemotion and was largely okay, this is the 199PS engine, I don't know the code as the van is now stuck in the garage until they can sort it.
I think I've read just about every thread about this bi-turbos going wonky. Does anyone have any success stories of everything being well after a turbo replacement, or is it possible the turbo failure was caused by something else I should be investigating?
Really sorry to hear this. Can I ask who the Leeds specialist is? I am in Leeds too.
That number brings up this at 2K - Darkside Developments
edit - its not in stock
The part number should be for an original vw unit which they are supplying new. They advised against a refurbed unit from midlands turbos / dark side.
The shop is IVC in Hunslet. Really nice guys and I’ve used them for years for DSG services. Came recommended by an auto electrician I’ve also been using for years. They run a very slick garage and the yard has always got at least a few transporters in it. Which could be considered a good or a bad thing I suppose!
Thank you. Alway on the lookout for a recommended VW place in and around Leeds.
Update:
Full replacement of turbo. Engine out job. 5k for everything. Out of limp mode and working as expected. Done almost 1000 miles now. There’s a slow coolant leak from one of the hoses now, I’m guessing related to the engine coming out so garage is going to look at that.
Also just replaced the factory original aux belt and tensioner as it was squeaking when cold which is how I discovered the coolant leak.
Praying it doesn’t start drinking oil at some point as per the horror stories on here.
My belt/tensioner started squeaking too. Just hope it does it when in for service in 1 months time so it gets done on the ALL IN.
They kept mine overnight to check in the morning as the squeal went once warmed up on mine. Covered on extended warranty though so good for that aspect
Posting an update on this for anyone troubleshooting in future:
The new turbo lasted less than 1000 miles before symptoms returned, limp mode when turbo called upon, getting worse and worse, after 800 miles or so I got a low coolant warning, topped it up and it was low again within another 500 miles with no visible leaks
Local garage pressure tested and no leaks, not good.
Full strip down and my suspicions were correct, it's a cracked EGR cooler, which requires a lot of disassembly to get to. Turns out coolant has been going through the engine and jamming up the turbo valves. So the 5 grand I spent to replace the turbo was probably not needed, great!
The garage is replacing the EGR cooler and the turbo actuator has magically unstuck itself, I'm hoping that after a few weeks of not feeing the turbo with burnt coolant, it will all gradually burn away.
So if anyone is getting weird turbo issues on their CXEC engine. Check your EGR cooler.
I'm around 8.5K in a hole for this so far including the turbo and really hoping this is the fix.
Jeez.
Thanks for the update...
Loosing coolant is never a good sign.
I’ve finally got the van back now. Bill was 2.5k for the new EGR cooler. No limp mode (yet) but garage seems to think the egr cooler failure isn’t linked to the turbo failing. So who knows?!
update: 200 miles on from EGR cooler replacement, it's not drinking coolant anymore but it once again went into limp mode with P00AF error code. Whilst just cruising along at 50mph on a flat road. Back to the garage it goes (again)
This is a whole brand new turbo unit and experiencing the exact same symptoms / failure as the turbo it replaced. Anyone got any bright ideas why that might be?
update, it's back in the garage again, just like the first time what started as occasional limp got progressively worse over a few hundred miles until it would go into limp as soon as you tried to pull away, DPF couldn't regain in limp so that's blocked (again) at 35g of soot.
No idea what to do at this point. They've replaced the entire turbo ( with the actuators) and the EGR cooler, anyone got any ideas what could be causing this? They pressure tested the vacuum lines that supply the actuators and they held pressure allegedly.
When you had the dpf back washed was the values reset? If not like mine I forgot and was doing constant regens which in turn, kept mine puffing sut out but no dpf light even though the levels was reading blocked
