Just out of interest, I noticed your flat tyre sensor warning light is showing. Does this happen often?Same here less than 2k on the clock T6.1 and it’s come up several times now. So do I need to book it in then ?
Hi Jonah! Did you manage to find out what was causing this? I've got exactly to he same fault. Seems to be indicating an issue with the steering. It's intermittent and everything seems to be working fine.Guess I’ve just joined this club now - nothing in carista to reset T6.1 69 plate with 19.5k
No fix to report. Seems to reset after ignition off for about 30mins. Not had it occur for while. Software gremlin? I’ve logged it with the service workshop but it hasn’t gone in as there currently isn’t a hard fault to investigate.Hi Jonah! Did you manage to find out what was causing this? I've got exactly to he same fault. Seems to be indicating an issue with the steering. It's intermittent and everything seems to be working fine.
My tyre pressure sensor comes on loads...never once actually lost pressure though. Mentioned it to the dealer last time it was having work done and they forgot to look into it !!!Just out of interest, I noticed your flat tyre sensor warning light is showing. Does this happen often?
Yep, I have exactly the same problem - always the near side front wheel! Given that my van still has all the original tyres with exactly the same mileage on each the dealer can't figure out why it keeps going off. Going in for an oil change shortly so am going to let them keep it until it is fixed.My tyre pressure sensor comes on loads...never once actually lost pressure though. Mentioned it to the dealer last time it was having work done and they forgot to look into it !!!
Let me know how you get on...Yep, I have exactly the same problem - always the near side front wheel! Given that my van still has all the original tyres with exactly the same mileage on each the dealer can't figure out why it keeps going off. Going in for an oil change shortly so am going to let them keep it until it is fixed.
For me nope, its because I have changed the wheels and havent put the sensors back in yetJust out of interest, I noticed your flat tyre sensor warning light is showing. Does this happen often?
Yes I get the feeling it's nothing to worry about but while still under warranty I should probably get it sorted. Hope it fixes the problem for you.My T6.1 is due into a VW van centre in a week or so. We had to wait a fair while for the module to come in but it's being replaced under warranty so will be able to report back whether it's fixed in not too long. To be honest it only shows up intermittently, I'd say about 1 drive in 10, so it's not too much of a bother. Just felt like I should get it sorted.
Brilliant. Thanks for that. Is the update you're having done something that'll be done while you wait?Hi,
16 weeks after first reporting this problem to VW and still no fix.
So, I emailed the entire board of UK and German Directors and asked WTF ?
(If you google this error message, it’s a known fault across the entire VAG range - the Guardian newspaper picked up on it earlier this year)
(( link : VW, Audi and Skoda owners angry over fault in SOS warning system ))
After being overtly on their case, it would appear that a software update is now available, as of 18/11/21, but I have been advised my VW will need to go in for it to be updated.
(I did ask if it could be updated over the air remotely, but no answer to that yet).
After 16 weeks of waiting for a fix, I’ve now been advised that there is a 2-3week further wait until they can book me in !
This is likely to be the last VW I purchase (personally and for my fleet) - lovely vehicles, but too many software glitches and complete lethargy from VW to acknowledge and fix.
If you have a similar issue, or another that you cannot get resolved, THE BEST EMAIL ADDRESS FOR VW ACTION IS THEIR CEO IN GERMANY :
[email protected]
I hope you all manage to get your VW’s fixed, I will be outing mine soon and going back to Mercedes - not quite as nice a ride, but I’ve found them to be more reliable and customer centric.
Regards,
I have waited 16 weeks !Brilliant. Thanks for that. Is the update you're having done something that'll be done while you wait?
Mine has just had a new module fitted and a software upgrade....done the trick so far.Hello everyone, I seem to have developed this issue too just the other day. I get a bell sound and this error warning which disappears once the engine is started. It's a 21 plate T6.1 and just over 3K miles. While I see quite a few people have also experienced this, I can't see whether it is something to worry about or whether anyone has actually had the matter resolved or has it resolved itself for anybody??
Great thank you. Just about to get on to the dealerMine has just had a new module fitted and a software upgrade....done the trick so far.
