Also ask them about the Bowden cable recall too. Drivers door handle used to freeze...now sorted.
Ta...too many years working in sewers on a bosun chair.Also ask them about the Bowden cable recall too. Drivers door handle used to freeze...now sorted.
Mine had a blown 20 amp fuse in the fuse box to the right of the stearing wheel ( right hand drive). Not sure why it blew but replaced and seems ok sinceIf you type into Google, "vw display sos error emergency: call workshop" you'll see that you are not alone!
Its part of the J949 SOS control unit, located behind the instrument panel.Jumping in here,
Have a T6.1 onsite with the same issue. We have however stripped out the front interior and re assembled so have been trying to get to the bottom of it. Can still make emergency calls as we have tested this.
We have looked at the fualt codes and there is a fault to do with a Back up battery for the SOS system stating that it is at the end of its life, anybody no where this is located?
I had the same issue with mine last Friday at Parkway Leicester after Bowden cable recall, van is a May 2020 and this was the first time the fault had shown.Currently sitting in Sheffield Van centre while they look at it…
I came to collect it after they did the Bowden cable recall and when I put they key in I got the SOS warning…. joy!
Mine is an April 21 same deal, never seen it before they touched it!I had the same issue with mine last Friday at Parkway Leicester after Bowden cable recall, van is a May 2020 and this was the first time the fault had shown.
Anyone no how to solve this ?This just came up on my Caravelle T6.1 Error: emergency call.Workshop! any one have any ideas? See photo attached. Thanks!!!
Go to your local dealer.Anyone no how to solve this ?
100% dealer. Its a known issue that requires a new module.Anyone no how to solve this ?
It’ll want a replacement sos unit. They were on back order.The SOS issue I had has now been resolved, by VW dealer resetting the SOS Module.
Van went in and came back out with the same fault. Apparently, I need a new SOS control module or something - on back order, waiting for an ETA......I've had an intermittent SOS fault, last week the van went in for service, and Bowden cable recall, apparently "new software" was also loaded to fix the SOS issue. Now have the SOS fault every time I start the Van. Booked back in on the 8th of July for investigation.
