Google VCDS security access modules 44 for the codes and/or ensure the bonnet is also open.
It won't work on the bench of there's and active fault code, you'll need to first clear the code.
There is error codes on this module which don't clear. i wonder if i can plug the motor into another t6.1 to clear the codes stored and then refit it with the CAN disconnected to allow the bench test method while fitted to the van
@solutionz have you seen/read Willem's Blog?
It is about PQ35 but perhaps you might find it useful.
I've compiled a list of some recent model EPS_MQB_ZFLS I've found mostly from VAG Coding Database - modules and component info and Ross-Tech Forums
It looks like the [5Q0 909 144 AA] or [3Q0 909 144 L] would do what I want however I'm not sure if they'd be physically compatible.
ModelPart number (SW/HW)SW / HWCodingConfirmed No
HCA below (km/h)
Multivan T6.1 20217LA 909 144 G
7LA 909 144 D
SW: 7160
HW: 751
9306
7LA 909 144 D
SW: 7160
HW: 751
0106
California T6.1 20217LA 909 144 F
7LA 909 144 D
SW: 7150
HW: 751
130650
Transporter T6.17LA 909 144 F
7LA 909 144 D
SW: 7150
HW: 751
0106
Caravelle 20207LA 909 144 F
7LA 909 144 D
SW: 7150
HW: 751
0306
TGE / Crafter 20202N0 909 143 G
2N0 909 143 C
SW: 7031
HW: 701
0107
A3 20205Q0 909 144 AB
5Q0 909 144 AA
SW: 1082
HW: 130
011F0000
T-Roc 20203Q0 909 144 M
3Q0 909 144 L
SW: 5082
HW: 507
951F0000
T-Roc 20195Q0 909 144 AB
5Q0 909 144 AA
SW: 1082
HW: 131
951F0000
Crafter 20192N0 909 143 G
2N0 909 143 C
SW: 7031
HW: 701
0107
Crafter 20192N0 909 143 E
2N0 909 143 C
SW: 7021
HW: 701
0106
Kodiaq 20195QF 909 144 B
5QF 909 144 A
SW: 5582
HW: 507
931700000
Arteon 20183Q0 909 144 L
3Q0 909 144 L
SW: 5081
HW: 507
13170000
Octavia III (A7) 20183Q0 909 144 L
3Q0 909 144 L
SW: 5081
HW: 507
911700000
Octavia 20183Q0 909 144 K
3Q0 909 144 H
SW: 5072
HW: 506
93070
Octavia 20185Q0 909 144 AA
5Q0 909 144 AA
SW: 1081
HW: 131
911700000
Golf VII 20185Q0 909 144 AA
5Q0 909 144 AA
SW: 1081
HW: 130
011F00000
They are physically similar and compatible.
Their measurements are similar.
The turns of the steering wheel are the same (+/- 488º) +/- 75mm
Rack stroke the same about +/- 75mm
As for the software:
1º ECU 5Q0 909 144 L Y M are compatible with each other.
2ºECU 5Q0 909 144 R, S, T, P, AA, AB are compatible with each other.
What I don't know if L or M are compatible with R, S, T, P, AA, AB
- L, M use 1 byte for encoding
-R, S, T, P, AA, AB use 2 bytes for encoding
Wow what an amazing thread I don’t fully understand it all , but , bloody amazing in depth , as some know I’ve fitting a rs3 engine in my old 06 t5. Bought the later subframe and a t6 rack hopefully works with power earth and signal to active , as there no room to a fluid steering pump on my engine
Sure I can do that.
So you basically want to know if the EPS will assist with 12VDC to KL30a, with or without SIG15?
Should be easy enough as I have one I can put on the bench with a battery. I'm also just waiting on a harness to get a bench setup working through J533.
Should it power up with ground/ kl30a 12v and signal 15 (switched igition 12v )as I’ve tryed 2 racks carnt get them to bench power up
terminal 15 is switched/ignition live
signal 15 is something different, its a signal ??
I tried with terminal 30 and 31 only and power steering works after completing the full clockwise and full anticlockwise rotation cycle.
Without terminal 15 the steering rack goes into permanent sleep mode.
So 15 is required to keep Power Steering Unit alive.
I tried with terminal 30 and 31 only and power steering works after completing the full clockwise and fully anticlockwise rotation.
Crazy 3 rd rack still won’t work
I assume this rack faulty then too / defo live and earth and signal 12v. It’s reads motor , but asked for basic settings tryed left to right still same is there any possible codeing I can try as there isn’t any showing
Are you planning to switch to T6.1 SUBFRAME?
Asking for basic settings but dosent work when moving steering full left full right , maybe codeing I’ve no idea tbh fed up of buying racks that won’t power up
Any link please ( issuise is as it’s a mixture of t6 and audi lot of things arnt compatible , Hernce I thought I could use it as a standalone idea
Reactions: mmi
