High - I've replaced a LED lens with a H4 lens. Theyre the sameWhat are the odds on the clear outer lenses of LEDs being the same as H4s?
This might be useful for some retro-fitters
Headlight range control module 6R0 907 357 C is used on number of other VAG models
so just in case if anybody is going to retrofit a second hand unit,
the following coding has to be applied
RHD: 0FCE020001000000
LHD: 0FCA020001000000
plus these adaptation values
ENG100660-PWM to Level Scaling Factor Front: -5.20 mm/%
ENG103748-PWM to Level Scaling Factor Rear: -5.60 mm/%
Security access key is 20103 or 96428 or 15284![]()
Yes it can and I am pretty sure that @mmi will be able to advise you much more.
great work. Do you know why you had to modify the coding? Do you have a complete coding that you did - i cant find @Montecha 's notes.Well following the info in this thread and pauly’s looms and guide, and the great help from @Grim Reaper with coding we got the lights working this afternoon
Following the coding list above we got a bulb warning light on and then lost main and full beam, with the added change to Byte 16 as @Montecha all full working and no faults or warning lights.
took it for a spin tonight and it’s like night abs day driving at night, expensive yes but highly recommend!
