I guess the only way to prove it would be to put a scope on it and see if the feed is PWM.
am i correct in assuming that the 0 or 1 at the end of each line means whether the bit should be ticked or not?I forgot that my retrofit was from twin H7 to LED and I didn't take in consideration upgrade from H4.
So complete VCDS coding for LED upgrade/retrofit from either H4 or twin H7 should be as follows
Byte 18 bit 0 1
Byte 18 bit 1 1
Byte 18 bit 2 0
Byte 18 bit 3 0
Byte 18 bit 4 1
Byte 18 bit 5 1
Byte 18 bit 6 1
Byte 18 bit 7 0
Byte 21 bit 0 1
Byte 22 bit 2 0
Byte 22 bit 4 1
Byte 23 bit 5 0
100% correctam i correct in assuming that the 0 or 1 at the end of each line means whether the bit should be ticked or not?
Iv installed my led lights and wired them up, changed the bcm coding to what was mentioned in previous posts by Robert. But im having issues.
everythings works as it should with ignition on, but wheni start the van the dipped beam goes off after 5seconds and wont come back on. If i hold full beam the headlights go wappy.
tried a battery d/c.
original headlights were h4.
original coding
A0AC393A0A61341193284F746CEB8E740F84710F60CC6D60330400230840
current coding
A0AC393A0A61341193284F746CEB8E740F84730F60CD7940330400230840
If anyone could help that would be great. Cannot drivein the dark at the moment
That’s standard behaviour before coding them inIv installed my led lights and wired them up, changed the bcm coding to what was mentioned in previous posts by Robert. But im having issues.
original coding
current coding
Iv done the coding as mentioned in previous postsThat’s standard behaviour before coding them in
You can buy my one as 2019 has dimming done from dash photo sensor not rotary button.Anyone provide them as struggling to find one ?
Looking at the code you posted, you still have the same 16 as your original code?Iv done the coding as mentioned in previous posts
Try value 77 in Byte 18, but can you also quote your both power module part numbers?Iv installed my led lights and wired them up, changed the bcm coding to what was mentioned in previous posts by Robert. But im having issues.
original coding
current coding
No not at the monent, just the headlights but ill be doing the level sensors in a month or 2Byte 16 is to switch off lamp monitoring otherwise you will likely get a warning light on the dash. (C0 is the new value).
Your byte 23 looks different. Mine is 60 (the same as your original) but your new code is showing 40.
Not sure if that will make a difference.
Have you fitted level sensors as well?
Byte 23 relates to things like whether your fog lights stay on with high beams and so on, they could well be different depending on preferences.Byte 16 is to switch off lamp monitoring otherwise you will likely get a warning light on the dash. (C0 is the new value).
