Hi @Pauly i would be very interested in knowing more about the loom you do aswell - can you pm me price and is it possible to see fitting instructions beforehand so i get an idea of the job? I've a LHD so im going to have to get the lamps here in the end..
Oh that's not good.. I won't be able to do this without that!I don't think he is making them anymore, he hasn't responded to any of my PMs I've sent to him about the headlight loom and the power latching kits.
I would be interested if the price is right!So putting the feelers out, who would be interested in a few months old genuine UK TPS sourced LED headlights, headlight LED ecu’s x4, looms (made by myself using genuine later type connectors (not the 1J0 14 pin plug used on the T5), level sensors and ecu for headlight levelling?
The headlights and led ecu,s x4 have the remainder of the two year warranty on them.
Loom set up for tailgate not barn door version.
ok thanks - do you happen to have the part numbers for these 14 pin plugs?I went through the wiring diagrams comparing my 10 pin H7 headlights to the 14 pin LED type.
I used the later type 14 pin plugs used on the later vans rather than the 1J0 numbered plugs, the terminals are much more substantial reducing contact resistance.
Also use grommets and blanks to seal the plugs.
You still should be able to avoid running your unwanted 6th core.
RHS
I would separate 2 wires(grey/red) at T73a/40(58R) and I would leave the wire(grey/red) going to the tail light connected there.
Then the other wire(grey/red) should be connected to T73b/6 (as you have planned originally).
LHS
I would reconnect the factory wire(grey/black) back to T73a/41(58L) and by doing that your tail lamp will be also getting correct feed again.
Then I would use spare wire(red/blue) (halogen manual range control - originally T10aq/2) and connect it to the lamp pin T14h/10.
Next at the other end disconnect T6ac/2 from E102 (halogen headlight range control unit) and connect this wire to T73b/5.
Job done, no need for any extra wires and no faults in the BCM.
Just read through the thread, it’s all there.Hi
I would like to change the lights in my T6 2019 , I had regular bulbs, I bought led lamps without a range module, please write how to connect the wires.
Thank You
Have a look below.Hi
Thank You
What's your 55 coding?Hi All
First, I’d like to stay what a great forum with lots of information as proven by my attempt to dive in the deep end and retrofit the OEM LED headlights thanks to everyone that has contributed to this particular post on how to do it (Pauly, Robert in particular).
Thanks to all the information here and with Pauly’s loom I now have the LEDs fitted and working, however, I have an error message on my range controller stating a short to ground:- I’ve attached the picture of the error below.
In my own investigation I have established that I have no voltage going to either Level Sensor. I believe I should be getting 5V across pins 1 & 2 at the sensor end but I have zip.
I have tested continuity at the Controller end and can confirm I have circuit to the front and rear. I am thinking that the range controller is FUBAR’d and although is getting 12volts in, it is not sending the 5V out to the levellers.
Before I condemn my controller and buy another I thought I’d post here to see if there was anything I was missing. Maybe a setting in the coding that switches on the voltage output or PWM for the controller to the levellers or if there was any other specific controller test that I can run. I don’t think so but any ideas are welcome.
Thanks in advance
