I'm not sure. I've got the package but not had a look yet.
Good info.I've heard that if you’ve got a van without Auto Headlights - so Startline or Trendline - you’ll be okay with the THQ T6 Full LED’s. It’s the Auto that plays havoc with the lights as they do a start up sequence & in the instance the lights are on Auto, they don’t know whether to put the light arrangement on automatically as requested by the van or do the little start up dance - subsequent error on dash then gets thrown up.
Im going to run mine manually for a few days to see if that’s right or not. The intermittent dash light doesn’t really bother me at the moment anyway but I wouldn’t expect to see these available for general sale anytime soon as THQ won’t release them until the issue is proven as fixed, or even allow dealers to fit them to Highlines anymore either apparently, for fear of a bad rep - which is fair I think.
what are those lights? I don't see them on THQ website...A company has just posted a reel of them....and oh my they look awesome
They are THQ ones, but not released yet. Was meant to be may 2024, then June, then July, then August.....what are those lights? I don't see them on THQ website...
I'm tempted on the aliexpress set. @Pewt has them.Good. Otherwise I would have to buy it...![]()
I agree. He did say that the motors for the levelling are the wrong way though, which I'm guessing is a simple wire swap to make them reversedBottom set seem more oem convincing to me....
Top set to me. More modern look, top led stripe, start animations + separate bottom drl for more aggressive lookI'm tempted on the aliexpress set. @Pewt has them.
Top set - THQ £895 (or there about)
Bottom set - ali express £620ish
It's on the advert for yoir lights....Mine have a start animation also ....i'll have to get a video.
It really isn’t noticeable unless you adjust them all the time. It’s only when you first set them up. I’ve never needed to lower them yet in the 12 months I’ve had themI agree. He did say that the motors for the levelling are the wrong way though, which I'm guessing is a simple wire swap to make them reversed
In such led lights it should be connected with auto leveling system, right? So motors will be used each time you turn ignition onIt really isn’t noticeable unless you adjust them all the time. It’s only when you first set them up. I’ve never needed to lower them yet in the 12 months I’ve had them
No. Only on the dash switchIn such led lights it should be connected with auto leveling system, right? So motors will be used each time you turn ignition on
I wonder what the issues wereThey are THQ ones, but not released yet. Was meant to be may 2024, then June, then July, then August.....
Still no date cause they're not happy with them. They said whoever has bought a set already (through supplier only) will have issues on their sets.
Have you got some sort of protector over the front?My Ali Express ones.
Seem solid enough (moisture ingress) but time will tell.
What a novelty it'll be, to be able to see on low beam
These won’t have the auto levering like your van will have. Like all the position sensors on the suspension.I'm still wondering - I have OEM led lights and I love them in terms of low/high beam, etc. The only thing is look of those alternatives... But as it's subjective the only valid question is what are disadvantages of replacing OEM led with Ali/THQ (beside quality which tbh is not always valid argument).
Are there any issues with i.e. automatic leveling, automatic high beam assist, etc?
