I had a delivery of my Solar panel last week, and today has been the first dry, not too windy day to try it on the roof and see how it fits.
First thing to check, yes it works!
It's a Victron 305w rigid panel, this is in basically full shade (a sliver of panel in the sun) and the sun 2hrs away from sunset.
So that's all good.
What's not so good, it is how it'll fit, with the plastic mounts that are mounted with sikaflex to the roof. There's just too much curve, front to back, on the VW T6 roofline for me to be happy. 4x corner mounts isn't enough to secure it, either, but putting mounts in the middle means the ends are about 2cm off the roof. I could make the sikaflex thicker on those mounts, and sit the panel off the mount slightly, but it's all a bit, well... crappy - and I don't want anything like that with a 20kg 1.5m long solar panel that could remove itself from the roof at 70mph.
I could have gone for a semi flexible panel like others but with the amount of these that fail, mainly due to heat, and my van being black, I wanted to go rigid.
Oh and I'm not drilling the roof. Not even an option.
So.
I've been having thoughts about getting a full size roof rack for a while now, and this has pushed me over the top on the decision.
Not only would a roof rack let me mount a rigid panel in about 20 minutes with just 6x bolted brackets, no glueing or bonding - and change panels if I want a different size or combination - it'll give me some much needed extra storage space, and also give me the option of fitting a roof tent if/when I come to want more sleeping space, without having to pay £5k+ for a pop top to be fitted. I'll also be able to mount an awning, led light bars, etc etc.
And as a bonus, it'll add to the "swamper" look that I'm going to be aiming for with an upgrade of wheels/tyres and suspension!
I'll need to get rid of the Fiamma F40 Van that's currently fitted as it uses 2x of the roof bar mounting points. I'll look at a replacement awning at a later date.
So, watch this space!
I have an expensive few weeks coming up.
