DOHAlmost, edit the last bit to Starter/Solar then Leisure.
Now it makes complete sense. Sorry you had to explain in numpty termsBasically the DC/DC charger needs somewhere to output its current to (a bucket if you like)
If you were to connect the solar input (hosepipe in) before the leisure battery the DC/DC charger would be trying to pass the charge through but have nowhere to put it (water everywhere) and I have heard somebody damaged their charger because of this.
It is not explicit in the manual, but there is a warning led that comes on if connection to leisure battery is not there when an input is connected, it doesn’t warn what might happen if you don’t sort it out and disconnect the input asap so it doesn’t get a chance to break anything.
Can you see this LED in the position you have installed your unit? Wonder if it could be extended or replaced with a buzzer?! Although I’m sure this is OTT as I will probably do it the old fashioned way and hang a warning label on it.
I thought that would make sense and what you might recommend.Just leave the blue wire disconnected (pull the fuse out) until you have the smart alternator fixed. It will work like it would if you didn’t have a smart alternator until then.
