It's an either / or, one is easier than the other but not as neat.
Hello Grim ReaperIf you disassemble the van to the point where you can get the fuse box unbolted (be wary of dropping bolts down the gap) you can remove the black plastic cover that covers the wire entries to the rear of the box, then remove the purple plastic combs that lock the wires that are already in place.
Tuesday,07,January,2020,17:54:08:35225
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 19.6.2.0 (x64) HEX-V2 CB: 0.4508.4
Data version: 20190930 DS308.0
www.Ross-Tech.com
Mileage: 130410km-81033mi Repair Order:
Chassis Type: 7H-VN75 (6N0)
Scan: 01 03 04 08 09 10 15 17 19 25 56 61 77 0B
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CAAC) Labels:. 03L-906-022-CAA.clb
Part No SW: 03L 906 019 GQ HW: 03L 907 309 L
Component: R4 2,0L EDC H38 8440
Revision: 22H38--- Serial number: 00000000000000
Coding: 01194012232401080000
Shop #: WSC 00215 210 00000
ASAM Dataset: EV_ECM20TDI01103L906019GQ 003006
ROD: EV_ECM20TDI01103L906019FH_003.rod
VCID: 005987507A8B9A97C97-8054
1 Fault Found:
7144 - Please Check DTC Memory in CAN Gateway (J533)
U1008 00 [039] - -
[Diagnostic interface for data busRead out DTC]
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 130415 km
Date: 2020.01.07
Time: 00:23:43
Engine speed: 857.50 /min
Normed load value: 18.0 %
Vehicle speed: 0 km/h
Coolant temperature: 88 ∞C
Intake air temperature: 37 ∞C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 14.140 V
Unlearning counter according OBD: 40
ACC target acceleration: 0.000 m/s≤
ACC control module received status-Bits 0-7: 6
Active brake system error status-Bits 0-7: 0
Status of ACC/CCS acceleration interface-Bits 0-7: 0
Acceleration: 0.000 m/s≤
Engine status: COENG_RUNNING
Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (-----) Labels: 7E0-907-37x-MK25AXT.clb
Part No SW: 7E0 907 379 L HW: 7E0 907 379 L
Component: ESP MK25A XT H50 0113
Revision: 00H50001
Coding: 108724AD09A8089D24A69076BA6592
Shop #: WSC 02757 790 49152
VCID: 3B2330BC536D394FDC5-806E
No fault code found.
Address 04: Steering Angle (G085) Labels:* 6R0-959-654.clb
Part No SW: 6R0 959 654 HW: 6R0 959 654
Component: LENKW.SENSOR H07 0070
Serial number: 04091404651402
Coding: 01
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_LWSKLOVW25X 005001
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA5F9A8007FEC67BBB-802A
Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb
Part No SW: 7E5 907 047 BM HW: 7E5 907 047 BM
Component: Climatic-T5 H20 0506
Revision: 00001012
Coding: 0000000003
Shop #: WSC 02757 790 50316
ASAM Dataset: EV_ClimaticT5 A01003
ROD: EV_ClimaT5Basis.rod
VCID: 7BA3F0BC136DF94F9C5-802E
Address 09: Cent. Elect. (J519) Labels:. 7H0-937-08x-09.clb
Part No SW: 7H0 937 090 D HW: 7H0 937 090
Component: BCM PQ25 Max4 H75 0725
Revision: B9075001 Serial number: 0671 260142655
Coding: A0F4793A0A613411922849706C2B8CD40780612F7E844C40320000020800
Shop #: WSC 02739 790 00000
VCID: 2F3B14EC9715D5EF60D-807A
Subsystem 1 - Part No SW: 7E0 959 801 L HW: 7E0 959 801 L Labels: 7E0-959-80X-V2.CLB
Component: J386__TSG_FT 003 8653
Serial number: KU0KU005091442484985
Coding: 1400B1
Subsystem 2 - Part No SW: 7E0 959 802 L HW: 7E0 959 802 L Labels: 7E0-959-80X-V2.CLB
Component: J387__TSG_BT 003 8653
Serial number: KU0KU010091442536913
Coding: 0400A1
Subsystem 3 - Part No: 7E1 951 172
Component: DWA-Sensor 00 001 0104
Coding: 000000
Subsystem 4 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Coding: 000000
Subsystem 5 - Part No: 7E1 951 172
Coding: 000000
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 K HW: 1Q0 919 475
Component: PARKHILFE 4K H03 0106
Revision: -------- Serial number: 32901421004149
Coding: 108001
Shop #: WSC 02739 790 50316
ASAM Dataset: EV_VW75XParkAssis4K 001004
ROD: EV_VW75XParkAssis4K_001.rod
VCID: 3A2D35B85CD70047C73-806E
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 7E0 959 655 B HW: 7E0 959 655 B
Component: VW10Airbag009 H07 0013
Revision: -------- Serial number: 003HL00SJXD5
Coding: 000000000000000000000000000000003039
Shop #: WSC 02754 790 50316
ASAM Dataset: EV_AirbaVW10BPAVN750 A01026
ROD: EV_AirbaVW10BPAVN750_VW12.rod
VCID: 3537268475C9EF3F2A1-8060
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 7E0 920 970 N HW: 7E0 920 970 N
Component: KOMBI H03 0805
Coding: 460A01
Shop #: WSC 02737 790 50316
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04727
ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 7H0 937 090
Component: GW-K-CAN TP20 H75 0725
Revision: B9075001
Coding: 042300
VCID: 70B9D7904AAB8A17397-8024
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H03 0805
Serial number:
Coding: 000000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6A8DC5F86CF770C7773-803E
Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 5M0 035 186 L HW: 5M0 035 186 L
Component: Radio RCD310 006 0119
Revision: 01000001 Serial number: VWZ1Z2P0270714
Coding: 05000200020014
Shop #: WSC 02754 790 00000
VCID: 353726847549EF3F2A1-8060
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 7H0 907 534 HW: 7H0 937 090
Component: Batt.regelung H75 0725
Coding: 030B7A73
Shop #: WSC 09999 999 999999
VCID: 6B83C0FC638D69CF0C5-803E
Subsystem 1 - Part No SW: 7E0 915 181 B HW: 7E0 915 181 B
Component: J367-BDM H08 0181
Serial number: 51232248082221647581
1 Fault Found:
02252 - Generator
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 199
Mileage: 130415 km
Time Indication: 0
Date: 2020.01.07
Time: 00:23:40
Address 77: Telephone (J412) Labels:| 7P6-035-730.clb
Part No SW: 7P6 035 730 M HW: 7P6 035 730 M
Component: TELEFON H16 4217
Revision: 1B001001 Serial number: 00007666625462
Coding: 0A01010000010101
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA_002.rod
VCID: 3C2133A056E33E77D5F-8068
End----------(Elapsed Time: 01:39, VBatt start/end: 14.3V/14.2V)-----------
Gateway Installation List: 6N0 909 901
01-Engine -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
Mileage: 130410km-81033miles
1 Fault Found:
U1008 00 [039] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 130415 km
Date: 2020.01.07
Time: 00:31:27
Engine speed: 860.50 /min
Normed load value: 36.9 %
Intake air temperature: 38 ∞C
Revision: 00H50001
Coding: 01
Revision: 00001012
Coding: 0000000003
Coding: 1400B1
Coding: 0400A1
Coding: 000000
Coding: 000000
Coding: 000000
Coding: 108001
Coding: 460A01
Revision: B9075001
Coding: 042300
Serial number:
Coding: 000000
Coding: 030B7A73
1 Fault Found:
02252 - Generator
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 199
Mileage: 130415 km
Time Indication: 0
Date: 2020.01.07
Time: 00:30:31
End----------(Elapsed Time: 01:39, VBatt start/end: 14.2V/14.2V)-----------
Coding: 030B7A73
1 Fault Found:
02252 - Generator
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 199
Mileage: 130415 km
Time Indication: 0
Date: 2020.01.07
Time: 00:30:31.
Sorry forgot you did this already!Post #9 in this thread and this thread Upgrading Starter Battery
my 2014 T5
In VW language your van actually is of Model Year 2015Vin with last 3 missing is WV1ZZZ7HZFH048
Do you think there is more I can do on VCDS to further identify what is causing this fault?Anyways, thanks for posting the VCDS Scan, seems that the "old" fault didn't disappear.
VCDS can do a few things:Do you think there is more I can do on VCDS to further identify what is causing this fault?
