transporter hq i believeAnyone had Leighton van do headlamp upgrade? Are they OEM or same as TransporterHQ?
Top result. Good to see you're not giving DVSA (was VOSA) a sniff of where this sensible tester is!Popped in to an independent vw garage today to have the headlight alignment checked. Turns out it was spot on- I did explain these were aftermarket units with HID bulbs fitted and the mechanic, who happens to be the MOT tester said they looked fine and in general as long as the install looks good will pass if the lights are working inside the cut off range. Guess I know where I will he getting future MOT’s done then!
Great Thankyou!! Ordering a set of hids now, did your led h1 work fine? I’m wondering if my led h7 are causing them problems as they worked fine before I installed them. also how did you get your dipped and main to stay on at the same time?I have tried all types of leds and the h7 are especially poor light output. I also tried the Philips h7 gen2 lights and some of the cheap Chinese bulbs gave far superior light output, they also gave a bulb out despite being canbus compatible.
I have just fitted a set of old h7 HiDs I had and the difference is night and day, they are 35w 4300k. I have stuck with the leds in the h1 though for quick startup. They seem to produce a pretty descent light and beam pattern.
My advice to all out there still trialling or contemplating led H7s is to forget it, stop wasting time and money and go down the HiDs route. The beam pattern is perfect and the output of light is especially good.
I have these fitted in the THQ GEN2 headlights
What bulb are you using in the H1 and have you a link?.
I know not cheap! Might just get these dipped HID fitted then hope they start workingWow...how much?....jees mine are staying yellow for that price!.
I'd pop some halogens in the dipped and test your LED H1s that way first. If you have a bulb warning light with dipped beam, the van will think they are not on, so won't give you main beam. Do they work when you pull the stalk towards you? You don't need dipped on to flash the lights, but if you have no lights turned on and push the stalk forwards, nothing happens.
The chances are they won't work with the HIDs either, unless they are super fancy pants CanBus ones that don't give a bulb error or flicker.
What age is your van. My 19 plate is far more temperamental when it come to these sort of things than the 68 I had before it.
@fezza68 I bought h1 ZES led bulbs think they are made by jamieWIN. They give a bulb out on dash but they do give excellent light output.What bulb are you using in the H1 and have you a link?.
