@Gadgets I'm not sure ref the vat info that you are saying about above
but would make the remark that the VAT status on a vehicle has no bearing in law on construction and use, it is down to the marker of N1 on the logbook, and the weight and layout of the vehicle as mentioned in the mass in service reference on the logbook. HMRC can change vat rulings, as dictated by the chancellor, whereas the construction and use are an altogether different matter.
Please note, no offence is intended by my remarks.
I will re post the letter from DVLA to
@Thogg below as it is current, and people can then read it again to make up their own minds. All this is a grey minefield, and you have to bear in mind
@Thogg s day job, yet we are still questioning this. I might suggest either an email from
@Pauly to DVLA, or like
@Thogg, you take the time to email DVLA with hour logbook details, and ask their opinion.
Thank you for your email which has been forwarded to me for reply. Please note that I cannot give legal advice, or give a definitive view on a particular vehicle, but I can point you to the relevant legislation.
Speed limits for vehicles of certain classes are set out in schedule 6 of the Road Traffic Regulation Act 1984.
Your vehicle has been registered as type N1 which denotes a goods vehicle not exceeding 3.5 tonnes maximum laden weight. You do not mention what body type is recorded on the registration document. If it states ‘panel van’ and the vehicle has been converted you will need to apply to DVLA to amend the registration document.
Change vehicle details on a V5C registration certificate (log book) - GOV.UK
As a goods vehicle the applicable maximum speed limits would be 50mph on single carriageway roads, 60mph on dual carriageway roads and 70mph on motorways.
However, if, as you believe, the vehicle qualifies as a dual purpose vehicle it will be subject to the national speed limits. As you are aware The Road Vehicles (Construction and Use) Regulations 1986, Part 1 Regulation 3(2) defines a dual purpose vehicle as:
a vehicle constructed or adapted for the carriage both of passengers and of goods or burden of any description, being a vehicle of which the unladen weight does not exceed 2040 kg, and which
]is so constructed or adapted that the driving power of the engine is, or by the appropriate use of the controls of the vehicle can be, transmitted to all the wheels of the vehicle; or
(ii) satisfies the following conditions as to construction, namely—
[if !supportLists](a) [endif]the vehicle must be permanently fitted with a rigid roof, with or without a sliding panel;
[if !supportLists](b) [endif]the area of the vehicle to the rear of the driver's seat must—
[if !supportLists](i) [endif]be permanently fitted with at least one row of transverse seats (fixed or folding) for two or more passengers and those seats must be properly sprung or cushioned and provided with upholstered back-rests, attached either to the seats or to a side or the floor of the vehicle; and
[if !supportLists](ii) [endif]be lit on each side and at the rear by a window or windows of glass or other transparent material having an area or aggregate area of not less than 1850 square centimetres on each side and not less than 770 square centimetres at the rear; and
[if !supportLists](c) [endif]the distance between the rearmost part of the steering wheel and the back-rests of the row of transverse seats satisfying the requirements specified in head (i) of sub-paragraph (b) (or, if there is more than one such row of seats, the distance between the rearmost part of the steering wheel and the back-rests of the rearmost such row) must, when the seats are ready for use, be not less than one-third of the distance between the rearmost part of the steering wheel and the rearmost part of the floor of the vehicle.
http://www.legislation.gov.uk/uksi/1986/1078/regulation/3/made
If your vehicle meets the above criteria for a dual purpose vehicle it should be restricted to the national speed limits of 60mph on single carriageway roads and 70mph on dual carriageways and motorways.
