Also if you do decide to go back to conventional Suspension the New KONI height adjust kit is a better offering than B 14 because it has damping adjustability as well as height and same price .
Solows are a great bit of kit, much better than b14s
Not anymore, I have asked the fitters to remove the VB Air and put the original suspension back onyou thought about adjustable polybushes on the rear?
It's a bit strange to have just one out by so much though![]()
Definitely wont adjust for cornering it simply doesn't react quick enough to function like that /Hi, do any of you vb owners know if the system compensates for changes such as when cornering.
Does it do the same as the airlift system and constantly adjust the bag pressure depending on the roll of the van.
I think airlift describe it as anti cross loading and axel equalization.
Also when its VW approved.
If theres a fault with say the compressor or management.
Is it vb who have to honer that or do VW.
I have a friend looking at air options.
I cant fault my van on airlift 3h and abp so far.
But the vb also seems a popular option worth considering.
Great thanks for your help.The Bilstein shocks will make the ride better at sensible drops for sure .. ITS always about the shocks .
The problem Air ride has is when its low there isnt enough pressure in the bags to function at normal Spring rates so it will ride hard as it bottoms on the bump stops.
It depends on your reasons for wanting VB in the first, I wanted it only for the self levelling but wasn't told it was at the expensive of tracking. It also makes the steering extremely light. I have done the B14's and levelling ramps on my Caravelle last year, should of done the same on the California....hind sight is a beautiful thingHmmm, still considering VB Air - but this is pushing me to want to have a drive / be driven in a van that has it first to make sure it is right for me. If anyone has it and lives within an hour / hour and half of Bromley and doesn't mind letting me have a quick look around then let me know. cheers
CZ.
If anyone is interested, I have the instructions for you to reprogram the ASCU via the hand controller which were sent to me by A & E Leisure. Not actually tried it as I no longer have the vehicle with it on.
DoneYes, please! Could you PM them?
Are these the instructions for calibrating the self levelling etc?If anyone is interested, I have the instructions for you to reprogram the ASCU via the hand controller which were sent to me by A & E Leisure. Not actually tried it as I no longer have the vehicle with it on.
