Well I've just re-read the whole thread from start to finish and I'm not sure I see any inconsistency? We are all entitled to our opinions and cognitive dissonance probably plays a part. If you're happy with it, enjoy it. I'm sticking to Koni Sports and hanging onto the £4k difference (or £5.5k if you contEli's unfortunate experience!)This seems somewhat inconsistent with Steve’s post here?
VB Air Suspension - Let's Discuss...
the shocks may be new but they are the same as OEM suspension. A & E Leisure told me its a full suspension systemwww.t6forum.com
Well I've just re-read the whole thread from start to finish and I'm not sure I see any inconsistency? We are all entitled to our opinions and cognitive dissonance probably plays a part. If you're happy with it, enjoy it. I'm sticking to Koni Sports and hanging onto the £4k difference (or £5.5k if you contEli's unfortunate experience!)![]()
We love our VB Air. In priority order I would say the benefits for us are Lowering, Self-levelling, Raising and then rarely used Sport.
But like the above our Converter has gone back to Rosmia, in our case to challenge the VB negative being connected directly to the battery and not via the VW Smart battery monitor.
could you throw some more light on the VB negative being connected directly to the battery issue please
Kurien, have a look at this thread which discusses negative battery connections.
Starter Battery Wiring - VW Disagreement
Interesting one. I've had a few problems with my starter battery discharging (its a Varta, not a Moll so thats not the issue!). Basically my battery goes flat after around 5-7d inactivity. Thats pretty short imo. This was an issue before lockdown and is not just due to the extended hiatus. I've...www.t6forum.com
We love our VB but do have to be careful with our vehicle battery and now believe this could be due to the VB direct connection to the battery negative post. As I have been led to believe, if the VW Smart alternator/ battery monitor (in Euro 6) doesn't know that the battery is being depleted (by the VB compressor in this case) it will not put charge back into the battery. This information has come from the Forum as I am not expert in automotive electrical systems.
I'll check how ours is wired up. We probably wouldn't notice any issue from it though as our battery gets trickle charged from solar so pretty much lives close to 100%. Anyone with a DC-DC charger probably wouldn't notice either as that would send the alternator high a lot of the time, which would have the side effect of charging the vehicle battery.
Maybe VB have changed the heights. When I had mine installed, I understood that Sport mode was just 20mm below Standard mode, which itself equated to OEM height. Exploria (who installed mine) now say that Sport mode gives a 50mm drop.Thanks @chriscroft ! I checked out the tyre fit site and it seems useful.
The sales guy at the company installing the VB told me that the standard height of the VB is about 30 mm lower than OEM suspension. Which then can be lowered another 30 mm with sports mode. This info is a bit different from what I read here at the forum, but I'll be wiser after the installation is done. He also told me that the shocks will be either AL-KO or Koni, but he couldn't tell which. That's a bit odd in my opinion. Maybe VB uses different shocks for different car manufacturers and he couldn't remember which one of these two is used with VW T6. I think I'll ask him again now that he has ordered suspension parts for my van. I know Koni is well regarded around here, but I'm bit unsure what to think about AL-KO. It only reminds me of finnish government owned alcohol retailing monopoly store which is called ALKO.![]()
Nice find and good translations. Thank you.Hy all,
I'm very interested in VB air suspension and so I'm looking for any information to get a good understanding about what it needs, what is it necessary to do and more.
Like this I found this "Einbau by HESS" video showing the installation of VB Full air on T6. I just translated to English its comments (in yellow color).
My questions is "Do you know exactly what your reseller did on your T6 to install it?" because I'm a little bit scared as he has to do many disassembly.
Have you got any technical documentation about this installation from VB Aire suspension?
