VCDS And Carista Fault Codes
Address 08: Auto HVAC (J255)
9480753 - Control/Display Unit for Rear Climatronic
B10AA 31 [008] - No Signal
Not much information available for this; it would seem to be a temporary communication loss with the rear climatronic unit.
Address 0B: Sec. Air Heating
02243 - Control Head for Aux. Heater (E407)
011 - Open Circuit - Intermittent
Aux heater was disconnected from the control unit.
Address 09: Cent. Elect. (J519)
03304 - Response Closing Status of Rear Right Door
008 - Implausible Signal - Intermittent
Door switch issue
Address 01: Engine (2D2D2-CXHA)
31391 - Manifold / Barometric Pressure Sensor (G71) / (F96)
P0105 00 [032] - Malfunction
Faulty pressure sensor, can cause limp mode.
Address 10: Park/Steer Assist (J446)
1113107 - Front Parking Aid Sensor(s)
B10FC 13 [008] - Open Circuit
Faulty parking sensor
1111316 - Speaker for Front Parking Aid
B10F5 14 [008] - Open or Short to Ground
Parking sensor bleeper fault
02745 - Bulb for Daytime Running Light; Left
010 - Open or Short to Plus - Intermittent
Lamp out warning
Address 15: Airbags (J234)
9440027 - Driver's side; side-airbag igniter
B100B 1B [136] - Resistance Too High
9439771 - Front Passenger's Side Airbag Igniter
B100A 1B [136] - Resistance Too High
Caused by ignition being switch on whilst seats were removed..
Address 56: Radio (J0503)
02877 - Digital Radio Antenna (R183)
011 - Open Circuit
Damaged, missing or disconnected DAB antenna
Address 18: Aux. Heat (J364)
0036 - Fuel Level too Low
P1250 00 [008]
Auxiliary diesel coolant heater was prevented from starting because fuel tank level was low.
Address 01: Engine
P019100 - Fuel High-Pressure Sensor: Error Message: Signal Improbable: Sporadic Fault
Flashing coil warning lamp, limp mode
Can be caused by a bad connection to the sensor.
Address 20: High Beam Assist. (J844)
15470084 - Module for High Beam Assistant
C10B2 F2 [008] - Function Restricted due to Mirror Dimming Over-Temp
[EC functional shutdown due to overtemperature in the ECU: functional shutdown]
Caused during a hot summer day.
Control Module temperature: 67 ∞C
Mirror dimming output stage: temperature: 69 ∞C
Fault cleared okay
01300 (carista) J401 - CDrom/Navi CAN GW
03158 (carista) J794 - CDrom/info elec1 CAN GW
Boths faults logged after OEM radio/navi removed and 3rd party aftermarket radio fitted.
A few engine related fault codes listed here ---> VW DTC List
Admin welcome to relocate.
03224 - Play Protection Active​
Sometimes referred as child lock activated. Actually I've seen when door lock was frozen and couldn't unlock nor lock from remote (was just driver door, others ok).​
03303 - Response Closing Status of Rear Left Door - 008 - Implausible Signal - Intermittent​
03304 - Response Closing Status of Rear Right Door - 008 - Implausible Signal - Intermittent​
As of Feb-2021 it seems that ODIS is ignoring these faults not being "real" faults. I had van serviced with fresh both faults, however I was informed that ODIS didn't show neither of them. Unfortunately due to Covid-19 restrictions I couldn't accompany technician.​
50990 - Sender/Receiver Module 2 for Interior Monitoring (G305) faulty -(RT)-
REAR
1078788 - Rear Left Parking Aid Sensor - B1076 04 [009] - Internal System Fault​
1078804 - Rear Left Parking Aid Sensor - B1076 14 [008] -- Open or Short to Ground​
1078825 - Rear Left Parking Aid Sensor - B1076 29 -- Signal Implausible​
1078833 - Rear Left Parking Aid Sensor - B1076 31 [009] -- No Signal​
1079044 - Center Rear Left Parking Aid Sensor - B1077 04 [008] - Internal System Fault​
1079060 - Center Rear Left Parking Aid Sensor - B1077 14 [008], [009] -- Open or Short to Ground​
1079081 - Center Rear Left Parking Aid Sensor - B1077 29 -- Signal implausible​
1079089 - Center Rear Left Parking Aid Sensor - B1077 31 [009]-- No Signal​
1079300 - Center Rear Right Parking Aid Sensor - B1078 04 [100] - Internal System Fault​
1079316 - Center Rear Right Parking Aid Sensor - B1078 14 [008] -- Open or Short to Ground​
1079337 - Center Rear Right Parking Aid Sensor - B1078 29 [008] -- Signal Implausible​
1079345 - Center Rear Right Parking Aid Sensor - B1078 31 [008] -- No Signal​
1079556 - Rear Right Parking Aid Sensors - B1079 04 [100] - Internal System Fault​
1079572 - Rear Right Parking Aid Sensor - B1079 14 [008], [009] -- Open or Short to Ground​
1079601 - Rear Right Parking Aid Sensor - B1079 31 [008] -- No Signal​
FRONT
1113107 - Front Parking Aid Sensor(s) - B10FC 13 [008] - Open Circuit​
1111826 - Front Left Parking Aid Sensor - B10F7 12 [009] -- Short to Plus​
1111828 - Front Left Parking Aid Sensor - B10F7 14 [008], [009] -- Open or Short to Ground​
1111849 - Front Left Parking Aid Sensor - B10F7 29 [008] - Signal Implausible​
1111857 - Front Left Parking Aid Sensor - B10F7 31 [008] - No Signal​
1112068 - Front Left Center Parking Aid Sensor - B10F8 04 [009] - Internal System Fault​
1112084 - Front Left Center Parking Aid Sensor - B10F8 14 [009] -- Open or Short to Ground​
1112324 - Front Right Center Parking Aid Sensor - B10F9 04 [009] - Internal System Fault​
1112340 - Front Right Center Parking Aid Sensor - B10F9 14 [009] -- Open or Short to Ground​
1112361 - Front Right Center Parking Aid Sensor - B10F9 29 [008] - Signal Implausible​
1112596 - Front Right Parking Aid Sensor - B10FA 14 [009] -- Open or Short to Ground​
13635840 - Supply voltage - U1011 00 [008] - Voltage too Low​
13893632 - Function Restricted due to Insufficient Voltage - U1400 00 [008]​
13632256 - Function Restricted due to Missing Message(s) - U1111 00 [009] - [Steuergerät für Anhängererkennung-J345 - kein Signal/keine Kommunikation]​
PARK ASSIST
1078858 - Rear Left Parking Aid Sensor - B1076 4A [009] - Incorrect component(s) installed​
1079060 - Center Rear Left Parking Aid Sensor - B1077 14 [009] - Open or Short to Ground​
1079089 - Center Rear Left Parking Aid Sensor - B1077 31 [009] - No Signal​
1079556 - Rear Right Parking Aid Sensors - B1079 04 [009] - Internal System Fault​
1079572 - Rear Right Parking Aid Sensors - B1079 14 [009] - Open or Short to Ground​
1079626 - Rear Right Parking Aid Sensors - B1079 4A [009] - Incorrect component(s) installed​
1079828 - Supply voltage for park assist sensor - B107A 14 [008] - Open circuit/short circuit to ground​
1079830 - Supply voltage for park assist sensor - B107A 16 [008] - Voltage too low​
1080083 - Rear Parking Aid Sensor(s)- B107B 13 [009] - Open Circuit​
1080580 - Side Rear Left Parking Aid Sensor - B107D 04 [009] - Internal System Fault​
1080596 - Side Rear Left Parking Aid Sensor - B107D 14 [009] - Open or Short to Ground​
1080836 - Side Rear Right Parking Aid Sensors - B107E 04 [009] - Internal System Fault​
1080852 - Side Rear Right Parking Aid Sensors - B107E 14 [009] - Open or Short to Ground​
1111572 - Side Front Left Parking Aid Sensor - B10F6 14 [009] - Open or Short to Ground​
233524 - Side Front Left Parking Aid Sensor - B10F6 31 [009] - No Signal -(RT)-
1112850 - Side Front Right, park assist sensor - B10FB 12 [008] - Short circuit to B+​
1112852 - Side Front Right Parking Aid Sensor - B10FB 14 [008] - Open circuit/short circuit to ground​
1112881 - Side Front Right t Parking Aid Sensor - B10FB 31 [008] - No signal​
233472 - Parking Sensor(s); Front - B10FC F0 [008] - Function Limitation due to External Factors​
233523 - Parking Sensor(s); Front - B10FC F0 [008] - Function Limitation due to External Factors​
233545 - Front Right Center Parking Aid Sensor - B10F9 31 [009] - No Signal​
Any info on what carista fault code?...central electronics 01838 rader interior monitoring control module 2 (g305)
I had the same fault code. Did you find out what it was?
I’ve got the same code, I think it’s for the alarm interior movement sensor by the tailgate. I’ve got a replacement part arriving next week, I’ll let you know if it clears the fault.
0036 [P1250 00] - Fuel Level too Low
Heater requested to start when Fuel low light ON (thus the request was rejected and fault flagged).​
The fault clears itself after a few hundred kilometers.​
0002 [B1389 F1] - No Flame Detected After Repeated Start Attempts
0005 [B1385 1B] - Glow Plug with Flame Monitoring
0056 [B1389 F0] - No Flame Detected During Initial Start Attempts
0057 [B138C 00] - No Fuel at Heater
0135 [B138F 00] - Heater Unit Locked
Locking release for T6: Basic Settings - IDE06654-Disengaging heater, and then clear the rest of the faults.​
0040 [B1381 00] - Shutdown by Battery Management Module
Van was not driven for 4 weeks, Webasto didn't start from a remote, however the van still cranked and started just fine. Temperature -1℃ .​
Battery Management (61) reported available charge 18 Ah (Battery 92 Ah, 2+ years).​
0266 - Databus
U1121 00 [009] - Missing Message​
[TIMEOUT mDachdisplay]​
No communication with Overhead Timer panel (module 6E: Ctrl Head Roof (J702)) (separately fused).​
Only with Webasto parking heater, SW: 7E0 963 272 B​
0280 - Local Data Bus
U10BA 00 [009] - No Communication​
[TIMEOUT FFBs_01]​
No communication with Remote Controller Receiver module (separately fused).​
0281 - Local Data Bus
[TIMEOUT FFBs_02]​
0373 - Supply voltage - U1011 00 [009] - Voltage too Low
0375 - Function Restricted due to Insufficient Voltage - U1400 00 [008] - -
0376 - No Basic Setting
B2010 00 [009] - -​
[INITIAL OPERATION MISSING]​
To clear the fault: Basic settings - Heater operation for production​
Aux. Heater related fault code in Address 19: CAN Gateway
01207 - Control Module for Auxiliary Heater (J364)
004 - No Signal/Communication​
Aux. Heater related fault code in Address 08: Auto HVAC
13701440 - Function Restricted due to Missing Message(s)
U1111 00 [008]​
Any assistance appreciated in finding out what error code 27078 (carista reading) means? 2017 T6 150 showing engine warning light engine running fine.
Address 03: ABS Brakes (J104)​
0320 - System Function Test Activated
C101F 00 [009] - -
0321 - System Function Test
C102A F0 [009] - Could not be Performed
Collected from the Forum posts ---> here
To clear the faults perform the procedure:​
(a PDF-copy attached)​
or possibly the function test can be terminated by VCDS (yet to be confirmed...).​
