Ill have a go at this.Use the measuring blocks to see what steering angle value is, its prob one turn out, if you measure it then you can take wheel back off a put it back to where it should be without recalibrating it
You guys are fast to respond!!Likely under:
What version vcds are you using?Does anyone know the security code for the 04 module??
Is it a cloan or genuine cable.?
What year van?
A screen shot will help?
Good morningAddress 01: Engine (J623-CFCA) (T5.1)
11866 - Position Sensor for Turbo Inlet Valve
P22D5 00 [096] - Implausible Signal
sensor connector was left unplugged
Carista is not at its best reading fault codes. I'd use another OBD-tool to get better understanding. Or simply reset engine faults to see if the engine management lights turns off, and the fault disappears.I have a code 02698 under engine on Carista.
I have now found a list of codes suggesting this is "front passenger side pedal switch"
Does this sound correct, would this display on Carista under engine issues, with the engine management light being on?
If so i assume there is a switch under the passenger seat swivel that has gone / come apart.
Any thoughts?
For info I have a petrol engine with an lpg conversion
Take #2 - could these be better explanations for the above? Any audio retrofits? E.g. similar to Can rear speakers be added to the standard head unit with front/ rear fader?I've got these faults come up on carista. They have just appeared after its first service at preston commercials.
First question is what are they,are the significant?.
Second,can i contact the garage and tell them I've got these faults and that i got them off my carista?.
They clear but come back.View attachment 91855
