VCDS And Carista Fault Codes
I would start your own thread and post a full auto scan (the file you sent me) and we can have another look
When scanning you want ignition on engine off
Address 01: Engine
15560 - EGR Sensor 1
P046C 00 [039] - Implausible Signal
This is a software issue in the ECU not a fault with the EGR the ecu has received a value it was not expecting VW advise to ignore/clear. May get fixed with a future software update.
Hello! I have this error. I got the engine symbol once. Delete the fault, the engine symbol was removed but the fault is still present in the carista and vagcom. Should we ignore it? At the VW and at another workshop they told me to change the EGR. I don't want to spend money on a simple failure. Thank you
Address 15: Airbags (J234)
12850432 - Databus
U1122 00 [008] - Implausible Message
[Bremse8 DLC Error]
unknown atm / possibly related to unplugging passenger airbag switch
I e changed my steering wheel to a mk 7 golf, I have now got this one. Does it need coding out?
Have you plugged the switch back in and reset the codes?
Address 09: Cent. Elect. (J519)
03303 - Response Closing Status of Rear Left Door
008 - Implausible Signal - Intermittent
intermittent/faulty rear door-lock status switch.
rear door lock carrier replaced by VW.
Getting this code just now. Tailgate won’t open!
