cgw
Hi Dellmassive, Thanks for the quick response, i have tried to clear the codes with carista, but it doesn't reset them.that issue will be related to the door lock/position sensors on the door.
Fault codes:
03301 Feedback Locked-Position Drivers-Door
03302 Feedback Locked-Position Passengers-Door
03303 Feedback Locked-Position rear-left
03442 Feedback Lock-Position Trunk
have a look here : https://www.t6forum.com/threads/vcds-and-carista-fault-codes.14143/
you need to clear the codes, key cycle and retest.
check the MFD dash is showing all the doors closed.
possible issues:
lock position switch,
lock SAFE position switch
wire issues in door loop
wire issue in loom running in van from bcm back to door (via under seat blocks)
T6.1 - Basic Equipment Wiring Diagram
Wiring diagrams covering basic vehicle equipment including various sensors, switches and controls VIP Membership is required to download this documentwww.t6forum.com
VIP Membership | VW T6 Forum - The Dedicated VW Transporter T6 Forum
The MFD dash shows all doors closed & disappears once the van is running & all doors lock/unlock with the key fob.
I was hoping VCDS may be able to reset the 4 locked position codes, these are recent, since i fixed the fault i had with my sliding door lock.
The Can network error has been there since i first got the carista & VW have blamed it on the conversion (which was done by a reputable converter)
if there was a wiring fault, i would of thought the problem would of been there all the time & not intermittent?
I haven't checked any fuses yet, so will have a look at those next!
