Hi all
Hope everyone is well and you guys had a good week so far.
I have a 2021 VW Transporter panel van VW1ZZZ7HZMH065264 that I cannot get to the bottom of it
The van was involved in an accident and tilt on the passenger side ( Uk Van) , Not a major accident, just some deep scratches and small dents, nothing major
Long story short, Since the accident, van has a rough idle and engine is shaking quite bad (Engine mounts and balance mount are ok, it's something from the engine)
If I am revving it until 1500 rpm engine is running rough, after 1500 rpm engine is running normal, smooth and no shakings
Plugged the diagnostic tool and only Active/Static errors that I am getting are:
P048000 - Cooling Fan 1 Control Circuit
P068500 - Glow Plug Control Module to PCM Comm Circuit Range/ Performance
P007D00 - Charge Air Cooler Temperature sensor Circuit High - Bank 1
P00A300 - Charge Air Cooler Temperature Sensor Circuit High - Bank 2
U041600 - ESP - Implausible Signal
The idea is that I have removed and changed the Glow Plug module and still does the same, Only strange thing is that I have measured the connections from the Relay and I don't have 12V, only 60-70 Ohm, Not even on the connectors from each glow plug.
I have checked all fuses (I think I found all of them)
Driver side under the light switch, battery location, Under the battery as well and one fuse under passenger seat.
All of them are alright but I still don't get 12V to the Glow plug relay
On another note.
Injectors were removed and sent to a Diesel Specialist to be tested , all came back without fault, measured voltage on each plug and it's ok, 5V each
The thing is that when I rev it up a 1500 rpm grey smoke is coming out like a nightmare from the exhaust, hence the thought that probably one of the injector is faulty. But no, they are alright
I am running out of options here so if anyone has a different idea or you've experienced this scenario before. I am all ears.
Thank you
On another note.
Thank you
