makes sense to me, that you need fuel (liquid) for the pump to work, and an airlock may form if it was dry.
so i can only assume that the return line and N290 valve must somehow allow self priming. . ?
it has its own fuel return line back to the tank, maybe that allows self air purging?
i dont know for sure as I've not been in this situation. . .
View attachment 238641View attachment 238642
but what i have done is run the tank done dry till the engine cut out from fuel starvation. . .
i then run to the garage as we all do, and buy £1M quid for a 5ltr plastic fuel can,
then fill with 5ltr of derv, then back to the van,
put it then crank the engine hard until the battery run flat - it didnt start. !!!!
called the AA, who arrived and said the fuel prime pumps needed to be run after a run dry,
so while he had the battery charging he done the laptop thing and run the fuel pumps, (mine had two, one in the tank and a second one in the engine bay)
then after that it took 3 or 4 goes and the engine sprung into life.
this was on my MY11 T5.1, but basically the same on the T6.
the lesson i learned was:
A - dont let a T5-T6.1 run out of fuel
B - if you do, make sure you have VCDS or Carista handy to run the lift pumps.
