[Guide] [T6_modified] T6 Webasto Aux/Parking (water) Heater Configuration with VCDS
This is a really interesting post. I am working on a friends van at the moment. It's come all the way from northern Norway to Scotland to be converted from a panel van to a family shuttle.
It has a Webasto coolant heater, factory installed, with remote module but NO REMOTES! I have ordered a new remote but will need to code it once it arrives. I've done a VCDS scan and noticed there is no label file for the aux heater. I haven't seen this before.
Do I need a label file before I can interrogate the module properly to code this remote or am I missing something obvious?
I have posted a request on the VCDS forum for some help but I noticed @mmi seems to be the resident expert in this section :)
VW Transporter 2012 - Webasto Aux heater remote coding (label file none)
Any help or guidance gratefully received.
Craig.
I see you have the roof controller installed, does it bring the heater on?
Yes it does. However, it think it has been factory configured to heater the engine first. I want to change this to passenger compartment only. Then code a remote because it already has the vw/webasto receiver wired into the van but the old owner must have lost the remote. Muppet ;)
Craig.
I'm afraid the label file is crucial for proper interpretation of codings/adaptations. Interested to see how this goes... keep us updated.
EDIT: Interestingly found out that I also have logged a scan without label file - from a MY13 Caravelle:
Address 18: Aux. Heat Labels: None
Part No: 7E0 815 071 C
Component: J737__Standheizung 0605
Revision: 00087000 Serial number: ...
Coding: 0020031
Shop #: WSC 02757 790 00000
VCID: 2514FB25B9E878CF7EF-8070
Mine also has no label?
Revision: 00087000 Serial number: ##########
Coding: 0000031
Shop #: WSC 83456 354 50561
VCID: 2541B9A1ECAF506C77-8070
No fault code found.
MY16:
Address 18: Aux. Heat (J364) Labels:| 7E0-963-27X-18.clb
Part No SW: 7E0 963 272 B HW: 7E0 963 272 A
Component: STH-T5GP2 002 0009
Coding: 5801
Shop #: WSC 45626 002 104857
ASAM Dataset: EV_AuxilParkiHeateWOST5G2 001013
ROD: EV_AuxilParkiHeateWOST5G2.rod
VCID: 2B000D1DD38C4EBFF7A-807E
Remote Control Auxiliary Heater:
Subsystem 1 - Part No SW: 5Q0 963 513 A HW: 5Q0 963 513 A
Component: R149 T91-LIN 003 0301
Serial number: 0000000000000.....​
Is it possible to add a label or does it actually look for a *.clb file?
If I have understood correctly the *.lbl file was the original plain text file format, which gradually has been replaced by encrypted .cbl format. Actually there are still in ..\Labels –directory many *.lbl files which are almost self-explanatory.
I think that the VCDS still accepts both, so basically could create one yourself or use an existing one just by copying and renaming properly.
Some Ross-Tech information:
MY13 Caravelle:
Coding: 0020031
Coding: 0000031
There is a one bit difference in the coding with the one I posted above yours (0000031 vs. 0020031) - would that one possibly tell to the Webasto to look for an overhead control panel?
EDIT: Please, ignore the above. Just found out that the MY13 Caravelle mentioned above does not have a overhead control panel :oops:
I have tried everything with the overhead panel coding, I think it may be a software issue with the unit! No matter what I do it always refers to 'Air' heater.
Some how I need to change it to 'Water' heater
Tough one :unsure:. I've found only codings 000103 and 000102 for overhead panels with water heater - in 5 different vans, however all with Webasto HW: 7E0 963 272 A as in MY16 above.
Interestingly both codings I have for your type of Webasto are: 0020031.
Assuming your everything included all these combinations.
This is my heater coding if it helps. Engine heating only no control panel.
Address 18: Aux. Heat (J364) Labels: 7E0-963-27X-18.clb
Part No SW: 7E0 963 273 A HW: 7E0 963 273 A
Component: STH-T5GP2 003 0009
Coding: 4101
Shop #: WSC 02737 790 50316
ROD: EV_AuxilParkiHeateWOST5G2_VN75.rod
VCID: 2B5093264221461A39-807E
Reactions: mmi
Here is the coding from the van I am working on. It has webasto water heater and control panel:
Part No: 7E0 819 008 D
Revision: 00084000 Serial number: 09019169F00000
Coding: 0001322
Shop #: WSC 02737 790 00000
VCID: 2A50CA338579C11AAB-807E
Address 6E: Ctrl Head Roof (J702) Labels:. 7E5-919-037-W2.clb
Part No SW: 7E5 919 037 G HW: 7E5 919 037 G
Component: Dachdisplay H15 0185
Revision: 10100011 Serial number: 239330
Coding: 000203
Shop #: WSC 02736 790 00000
VCID: 356AE94F9CC79EE236-8060
Ross-Tech site has a scan with exactly the same components and revisions (your 6E revision??) - and no air heater ===> Ross-Tech Forums
Revision: 00087000 Serial number: 09024900A00000
Coding: 0020031
VCID: 25413BE9ECFDE236C75-8070
Address 6E: Ctrl Head Roof (J702) Labels: None
Part No SW: 7E5 919 037 F HW: 7E5 919 037 F
Component: Dachdisplay H16 0185
Revision: 11100011 Serial number: 295793
Coding: 000206
Shop #: WSC 02756 790 00000
VCID: 3467D6AD97278BBE40B-8061
Many thanks you guys, I'll try these tonight and let you know, it may be later on as the wife has taken van again!
I've tried a few of these setting with no joy, when I run an autoscan, I'm getting 'Malfunction 0010' on
Auto HVAC
Cent Elect
Aux Heat
CAN Gateway
But 'Not registered 0011' for the 6E-Ctrl Head Roof module
Maybe I'm programming it incorrectly!
Auto HVAC
Cent Elect
Aux Heat
CAN Gateway
A communication problem? Perhaps you could post here a full autoscan - there should be "better" fault descriptions in the modules sections? :unsure:
I have managed to find the time to do a full scan, I have attached it, if anyone can help me out with this I would be grateful.
  • Log-WV2ZZZ7HZFH066657-78660km-48877mi.txt
Reactions: mmi
