WEl.. I did reflash with 7E0 963 272 B now, and it still doesnt work at all.. Bugger...
Did you clear all the faults?WEl.. I did reflash with 7E0 963 272 B now, and it still doesnt work at all.. Bugger...
Yes, something not right - wiring?There we are.. New scan done. Strange enought.. the telestart module doesnt show up anywhere..
Address 18: Aux. Heat (J364) Labels:| 7E0-963-27X-18.clb
Part No SW: 7E0 963 272 B HW: 7E0 963 273 A
Component: STH-T5GP2 003 0009
Coding: 5901
Shop #: WSC 07383 005 104857
ASAM Dataset: EV_AuxilParkiHeateWOST5G2 001013
ROD: EV_AuxilParkiHeateWOST5G2.rod
VCID: 2B55B2AB420539D1C4-807E
0058 - Local Databus
U1030 00 [008] - Electrical Malfunction
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 129
Mileage: 91192 km
Parking heater: operating condition: System malfunction
71
Coolant temperature of parking heater: 17 °C
Coolant temperature: -48 °C
Engine running status: not detected
Fuel level: 58 l
Heating performance: 0 W
0048 - Control Circuit for Front Air Blower
B10A0 15 [009] - Open or Short to Plus
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 89
Mileage: 91192 km
Date: 2022.07.15
Time: 11:11:27
71
Coolant temperature of parking heater: 16 °C
Coolant temperature: 15 °C
Fuel level: 58 l
Thank you - even better now - 4 new faultsI havent done much with wiring at all.. I'll look in to it..
Addin new scan after dtc clear
Early T6s have remote control receiver 5Q0 963 513 A (with oval remote controller). From MY2017 onwards remote control receiver is 3Q0 963 513 (square remote). However, I'm fairly confident they both work - because both of them were installed with exactly the same heater.what number on in should i get? i have seen 2 numbers around this forum and im not sure what is correct on mine.
