Webasto Auxiliary Heater - customizing
I think when you flash the software in the heater it reverts back to webasto software.
So thats why the vw telestart might not work
I do not understand? changed software. Remote control webasto T91 Starts the heater and Climatronic, and when starting with webasto T91 lin 3Q0 963 513 the heater does not start(. Maybe you need something to encode VCDS?
If I understood correctly:
1) You have a “round” upload_2018-12-12_19-32-13.png remote T91 which starts the heater ok ?
2) But you have replaced old receiver module with the new one (in your picture and below) - true??
3) You are trying start the heater with new “square” remote but this does not work?
I would guess that after installing your receiver module you need to pair your “square” remote with the controller box (I do not know if they come paired).
The VCDS should be able to do the pairing as described at Ross-Tech site Cannot learn aux heater remotes...?... which states that: “The proper procedure can be found in basic settings under IDE06650 "Adapting RF transmitter".
What is a concern is your mention about "changed software" :unsure: ?
You're right. Was originally a universal kit webasto T91. Then it was decided to change this kit to OEM T91 Lin, mentioned above. The key FOB was tied to the transmitter, but it didn't work. The connection between the keychain and the unit is, but the heater does not start (.
ell me what I'm doing wrong, but a heater installed from the factory on VW T6 work for both sets?
Hmmm... not sure. Is the heater software still the original VW software, or was it changed to Webasto software when the universal kit was installed as mentioned in post Webasto Auxiliary Heater - customizing Do you see the Webasto in VCDS Scan? Do you see remote controller/receiver?
As far as I understand your new receiver module 3Q0.963.513 is the right one for a T6.
Attached below a scan and coding of Webasto + remote from a T6 using the same receiver and same remote.
Address 18: Aux. Heat (J364) Labels:| 7E0-963-27X-18.clb
Part No SW: 7E0 963 272 B HW: 7E0 963 272 B
Component: STH-T5GP2 003 0009
Coding: 5901
Shop #: WSC 28624 002 1048576
ASAM Dataset: EV_AuxilParkiHeateWOST5G2 001013
ROD: EV_AuxilParkiHeateWOST5G2.rod
VCID: 2B000D1DD38C4EBFF7A-807E
Remote Control Auxiliary Heater:
Subsystem 1 - Part No SW: 3Q0 963 513 HW: 3Q0 963 513
Component: R64 D208L 004 0402
Serial number: 0000000000000039xxxx
I don’t know if that’s an activation issue as the softwares aren't probably compatible any more. Not sure even if VW could reprogram the heater back to original software.
Адрес 18: Дополнительный/автономный отопитель (J364) Label:| 7E0-963-27X-18.clb
Part No SW: 7E0 963 273 A HW: 7E0 963 273 A
Компонент: STH-T5GP2 003 0009
Кодировка: 4000
Мастерская #: WSC 02762 790 50316
Метка файла ASAM/ODX: EV_AuxilParkiHeateWOST5G2 001013
I am satisfied with how to start the heater from the universal webasto telestart T91. I only want to connect OEM remote control T91 lin instead of telestart. Has anyone here done this?
Кодировка: 4000
Now I'm confused, the software looks like OEM VW. If so, I think the coding "4000" tells heater that there is no remote control? Should you change it "5000" - byte 0, bits 4-5?
Замена кодировок Байт 0 Бит 4-5 ни к чему не приводит(. Без этих кодировок работает универсальный webasto T91
Replacing Byte encodings 0 Bit 4-5 leads to nothing(. Without these encodings works universal webasto T91
Do you think VCDs - 18 group - 5901 encoding will help, or something else should be activated?
I think you should try only "5000" because that would change only bits 4-5 which should only enable remote control and doesn't change anything else. This is the only coding related to remote module.
Edit: I just looked at this a 3rd time as yes it supplies a 12v feed to a wire on the heater control unit.
@Loz, do you know if this single 12v input to the heater control (pin 1 on the red plug under the left seat?) starts both the coolant heater and the cabin fan? Am I correctly assuming that the heater control unit will need to be flashed before it will accept this input?
I dont haver a cali but I do have the coolant auxiliary heater ,I think the wire you are talking about only controls the
Auxiliary heater .
On my instructions it said this wire was not there on later models ,if this is the case then you have to wire direct to the heater
Auxiliary heater .
Ok, thanks
You don't need special kit to upgrade Engine Heater to Parking Heater.
In my Transporter T6 / Multivan Diesel with Engine Heater 7E0 963 273 A, I update software using ODIS with firmware FL_7E0963272B_0009 ( dedicated for Parking Heater 7E0 963 272 B) and in this way Engine Heater has been unlocked and now working as a fully Webasto Parking Heater.
I added Telestart T91 LIN module (5Q0 963 513 A) and changed coding from 4101 to 5001 - and now remote control working.
Part No SW: 7E0 963 272 B HW: 7E0 963 273 A <- after update
Coding: 5901 <- new coding (old was 4101)
If someone need help I will be glad to help you.
