They’re no good for my poptop as the gap between the brackets is too small, and you can’t pull the roof down tight enough.
John.
That’s what I use for the holes I made.Picked up a tin of Hammerite direct to rust metal paint.
Question: can I use this to paint over the screw holes in the van floor to protect them from rust?
I was thinking to fill in the holes after seeing another post suggesting it.
I have been considering those but like you when they are pulled nice and tight on my roof, there is only about the distance of the buckle between the 2 brackets, so it would in fact be worse using those things. A shame really as it would be better to use.They’re no good for my poptop as the gap between the brackets is too small, and you can’t pull the roof down tight enough.
John.
Fingers crossed on mineThey’re no good for my poptop as the gap between the brackets is too small, and you can’t pull the roof down tight enough.
John
Dog looks a bit worried! My wife gave me the same look when my camper glass delivery arrived!!Slowly filling up the house with purchases!
Silent coat, thermal liner & windows from camper glass
Cool thanks…@Bridger8 yes that's the name of it. I picked up white as my van is white, but they also do it in black:
Hammerite Black Gloss Metal paint, 250ml
A popular Hammerite interior and exterior gloss metal paint that is a great choice to give your home a refresh. Black is a timeless colour that will add a contemporary feel to your design. The paint is recommended for use on iron. After application, this metal paint will accomplish a flawlessly...www.diy.com
Looks like you can get it elsewhere for a tenner! (Amazon/Toolstation)
An OEM brake hose leaking???? I wouldn’t class any leak on a brake hose as small, what was the root cause?A set of these after I noticed one had sprung a small leak
I have no idea mate, one minute nothing then a brake fluid low level warning appeared.An OEM brake hose leaking???? I wouldn’t class any leak on a brake hose as small, what was the root cause?
Today I picked up some sikaflex to fill the holes once I’ve painted them.Picked up a tin of Hammerite direct to rust metal paint.
One of these. Quite impressed with the reception. Only tried at home so I'll check it out next week when I'm in the Yorkshire Dales.A WiFi Freeview TV Receiver for my iPad.
Only cost £38 and means we can watch TV without using or needing to have data.
Comes with power lead, small aerial (fitted) larger aerial and coax adapter.
Wi-fi Freeview Tv Receiver For Smartphones And Tablets
Buy the Wi-fi Freeview Tv Receiver For Smartphones And Tablets at Robert Dyas online. Free Standard Home Delivery when you spend over £30www.robertdyas.co.uk
And fitted although not the easiest of task when the brake pipe but won’t budge. Still found a way around it. Front done.I have no idea mate, one minute nothing then a brake fluid low level warning appeared.
I checked my drive and notice a patch of darker tarmac which I had noticed earlier that evening. It was dry hence my instinct kicked in and I checked my brakes to find the fluid on the floor.
Keeping up the pink theme?!!!And fitted although not the easiest of task when the brake pipe but won’t budge. Still found a way around it. Front done.
Next, the rears, anyone know why they sent me six braided hoses
