Thank you @Ayjay . That is a lot of interference indeed. With the 928, if I wanted a bit more clearance, it was just a case of using longer retaining cables which can be purchased from any hardware shop. It is easy. As you very rightly mention - cutting parts may compromise the structural integrity of the carrier. That will not be advised.@kurienp - Here you go. If you need anything else, just shout. Are you contemplating a possible modification? I considered it but am not smart enough to tell whether cutting away the necessary piece of plastic would damage the structural integrity of the rack! I suspect I'll just live with it as is.View attachment 100373View attachment 100374View attachment 100375
If you don't mind please, one more pic - of the hinge mechanism if possible - where the tilting rack joins the lower tow bar bracket. If we can get it to tilt another 10 or 12 degrees, the tailgate should clear.
