Look at all that space!Started the leisure battery set up! View attachment 246886
I know I was pleasantly surprised! The XS definitely helps matters! At least I know I won’t have an issue getting a solar controller in there tooLook at all that space!much easier than fitting the 230Ah, that's for sure!
Baggsie you hold the nail!Sledge hammer and nail it is then.
It's surprising what fits even with the 230Ah, you just need to be (much!) more careful with space.I know I was pleasantly surprised! The XS definitely helps matters! At least I know I won’t have an issue getting a solar controller in there too
Think along the lines of Some Mothers Do 'Ave 'Em - Frank Spencer not Micheal Crawford.Exactly how ham fisted is one?
Put a dust sheet down below each wing mirror before you start Bav...or the one for the other side
Just in case, I have a couple of neodymium magnets, but, yes, a light coloured dust sheet would seem eminently sensible.Put a dust sheet down below each wing mirror before you start Bav![]()
@Bav - Man pride is easily resolved, with plenty of beer for the workers and helpers.Wayne, Wayne, Wayne - I may be feckin useless at all things requiring manual dexterity, coordination and mechanical sympathy, but I still have my man-pride!!!
Pin drillI was hoping to use the hot pin method to make the pilot holes, as I don't trust myself to be within 10' of the van with a drill in my hand!
I do wonder if that is compact enough to get around the standard wiring...Look at all that space!much easier than fitting the 230Ah, that's for sure!
I’m new to all this, but planning ahead for replacing the split charger. What does the smart shunt do? I thought battery monitoring was built into the Orion XS? Do you need both?It's surprising what fits even with the 230Ah, you just need to be (much!) more careful with space.
MPPT 100/20 (anything bigger won't fit)
Orion XS
Smart shunt
Cerbo GX (to be fitted but it will go in behind the Orion)
2x 4 way fuse boxes
2x isolator switches (one big, one small)
And associated busbars, distribution boxes etc.
Basically that ^^An external shunt can measure the current in and out of the battery to get a fairly accurate measurement of charge, plus it's very easy to see how much load is on your system.
Is it essential if you have a good BMS with monitoring and a good charger with monitoring, no, but if you like knowing what's going on in your system and you intend doing a lot of off grid the more information the better.
Hey @Jamiedh ... What are the wheels on your van ? Also what size?..... Need something smaller than my comedy 20s... Liking the bronze look.Bought some roof rails and bars for the surfboards. Have just placed them on for now, need to get brave and drill some holes tomorrow!
Joking aside, put an old sheet or similar on the ground under the door. It’ll stop the screw bouncing away and you’ll see it a lot easierI am that ham-fisted clown who'd drop the screw and for it never to be seen again - hence my reticence in fitting the damned things.
