Rotate your device to landscape and you'll see signatures. I only learnt that recently!@TallPaul_S I'm struggling to view signatures on this mobile browser, do you have a link to your build thread please?
Got it, thanks@Vroomfondel Turn your phone to landscape mode. Signatures show up then when on your phone.
You've saved Monday! well done!YESSSS!
Found it! I was very close to ordering another from Amazon, that's a tenner saved!
In a random box of car/DIY bits in the garage that I'd been using when I last worked on/in my car
I'll get that touched up tomorrow, and also the gouge that the sliding door took out my lower runner when the wheel bearing went!
Could you put it behind a wing mirror cap?Just set up some Ruuvi tags for the van. Inside temp, outside temp and fridge temp. The fridge isn't on at the moment.
I'm currently testing what the temperature difference for the outside one is between being in the shade Vs being under the solar panel - hoping to bolt it to the roof rack between the rack and the panel.
Looks like that's not an option. It was sitting at 27-28 degrees in the shade, under the panel also in the shade and it's at 32 degrees and still climbing...
Need to think of a better location then! Needs to be out of the direct line of fire of rain/spray and also not in direct sunlight.
Under the van somewhere tucked up away from the exhaust etc might be an option. I've seen people put them inside fuel filler cap too.
Yeah I thought about that but tbh I've not actually removed one. And I have heated mirrors so I'd assume that might affect the reading in winter.Could you put it behind a wing mirror cap?
Looking goodFitted a passenger swivel base
Nice is that offer still on? I need dodomatTook delivery of these. 20% off on eBay through the app using code APPY20.
Also have a load of dodomat coming - wasn’t planning on doing it but the discount was too good to ignore
Expires today.
I need to do the whole van. Since taking that bulk head out there is so much noise. I do see most people saying the rear floor isn't worthwhileSound deadened the scuttle panel. Definitely makes a difference.
Yeah it ends today. Need to use the eBay app on your phone for it to work - it won’t work through the web browser.Nice is that offer still on? I need dodomat
Don't suppose you have a link to the sound deadening that the discount works on?Yeah it ends today. Need to use the eBay app on your phone for it to work - it won’t work through the web browser.
Your a star thank you mateDodo Mat DEADN Hex Sound Deadening 50 Sheets Car Van Vibration Damper Proofing 5060675880036 | eBay
Dodo Mat DEADN Hex is a self adhesive, foil backed sound deadening vibration damper. Dodo Mat DEADN Hex 50 Sheets. To maintain flexibility and ease of cutting we also employ our unique Hex embossing pattern.www.ebay.co.uk
