The W/ Wh and solar output you get from a system depends on the state of the battery and the loads that you are running at the time.
if your battery is fully charged and you have no loads switched on then you will have no w/wh shown.
where as if you have a low battery and have all your loads switched on, there will be a demand for power so the MPPT should run in BULK mode show a large wh haul.
so if you want to max out your solar to see what you can achieve (max watts with miday sun etc ) . . . you need to load up your leisure battery with everything you have.
i normally use a 100w inverter and 240v heat gun or a 40A Tyre inflator . . . start this running then watch you watts go up to max.
as an example here is the readout from the solar shed . . . . the batterys are fully charged every day and only drain down 10% over night from the LED lighting.
the system is fully charge again by 7am . . . . so i show a low system yeild / w /wh.
450w of panels on a 100/20 MPPT.
View attachment 114479View attachment 114480View attachment 114481View attachment 114482
same data from VRM cloud . . . but just today.
