Then there is tyres...Now you know the offset you can pump it into “will they fit” my cantera were 8 inch offset 43 they were fine with a 5mm shim. Im pretty sure that anything as wide as the 8.5/9 fronts will need a 35 offset on the front. 43 is spot on for the rear. You may need a spacer on the front but not much. Only way it to try it without and see what rubs. You won’t hit the strut
