Which? Aftermarket Headlight choices
Has anyone fitted an HID kit to the THQ V2's yet ?, I find the dipped beam output to be a shade poor and am considering fitting one ( if I can find somewhere to stick the ballasts ), it made one hell of a difference to my old 5.5 passat .
We’re look for a light upgrade that is either original vw bi-xenon or looks as close to them as possible, has anyone got any recommendations on where to buy them from or decent alternatives?
Thanks for your help
VW did not do Bi-xenon on the T6, so I assume you mean LED?
Genuine LEDs are very expensive, full retrofit with levelling is over £2k unless you DIY it and buy bits off ebay etc
The other option that looks similar(ish) is the thq or travelinlite aftermarket headlights that have an LED strip for DRL around bottom of headlight
Just make sure you get the upgraded bulb. We use travellinlite, but I think they are all the same?
Hi which ones were these off the site and were they easy to fit? Lovely bus by the way
They are from travelin lite, apparently they are plug and play so should be easy to fit, 2 bulb options £400 ish or £600 ish
